Question about Ovens
Wolf Range model # DF364-C-LP. Getting an error message "ERR OC" on the panel. Over was preheating when it turned off.
Posted by glma3998 on
Gere knutson
  • 842 Answers
According to the service manuel for this unit you will need to replace your controller, somehow you lost communication. Part number you will need is 806827.
Before you order this I would locate you local dealer or call Wolf and look into the warranty status, this repair should be done by a certified technician.
Call 888-833-0306 this is a distributor of Wolf and can get you the part you need, or 1-800-919-8324 for factory assistance to get this problem taken care of or direct you to a servicer in your area.
This part is pricey, and not easy to have changed out. I have changed one before and is tricky to work with the bullnose on this unit.
I know this information is not what you wanted, but at least I and able to direct you in the correct direction to repair this problem.
I hope this was helpful
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Aug 14, 2011
Testimonial: "Quick and very helpful advice"
I have a 30 inch wolf range I took the door off of. I'm trying to take the door apart but there are 2 screws behind the logo plate that need to come out. The problem I'm having is getting the logo plate...
A plastic putty knife can help, but the logo is held on with double sided tape and the Wolf parts book always says to order a new logo whenever you order anything that requires removing the logo
Aug 07, 2013 | Wolf Range WKGD-2 Gas Double Oven
Display shows err 08 message
It looks like a Samsung Oven and the E08 is a preheating error
It could be a relay or a defective Thermostat. If U have food in the Oven during the preheating that can cause the error as well...
The error occurs if the oven doesn't reach its tempt with in 50 mins
Dec 22, 2012 | Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Message "F1" in the display.
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 24, 2010 | Frigidaire Ovens
When the oven is turned on to preheat, the buzzer goes off and an "F1" error message is displayed and the oven turns off. The model # is MGR5750ADW. Is there something we can do to fix it?
An "F1" error code means you have a defective clock assembly (also called ERC- electronic range control). You will need to replace the clock assembly, and they are not cheap, around $200. Hope this helps you, good luck.
Oct 04, 2009 | Maytag Ovens
Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 26, 2009 | Wolf Range WKGD-2 Gas Double Oven
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Ovens Logo
466 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
