This is not the auto shut off that it does in case it has been left on too long. Mine shuts off even with the "hold" button on, 5-10 minutes into listening to mp3s or the fm radio. Then, repeated attempts to turn it back on are futile. The dang thing just acts dead. A few hours later I can turn it on again, but the same thing happens. And the battery registers as half or completely full, so it's not that either. This is probably a hardware/wiring problem, huh? Has anyone had luck sending these back to the manufacturer for fixing?
Thanks.
SOURCE: sansa e140 just need some help with menus
When you power on your MP3 player it will go to the FM radio. 1. Press menu.
2. Go down once and you'll be on "Mode". Press the right button to access the mode menu.
3. You either press the enter button after accessing the menu or go down to select Playback mode (I forget which one it is).
Good Luck!
SOURCE: sandisk sansa clip mp3 shuts of and wont turn back on...
You can set the timer under Auto Power Off and Sleep settings to turn off the Sansa
player automatically when it is playing for a certain time.
1. Press Menu button to return to the Main Menu.
2. Move to Power and select it.
3. Select Auto Power Off or Sleep.
-Tha Mp3 Doctor
SOURCE: when my data base comes on it shuts off.Goes to fm radio.
i cant put music must do the think put it music steven
