SOURCE: On a Cannon Powershot IXUS 86015 How do i change the language back to english?
Hey thaze,
According to the manufacturer you need to press the playback button, which looks like a triangle pointing to the right. Next you need to hold down the func. /set button, and press the menu button. Next you need to use the up/down arrows, or the right/left arrows to choose the desired language and then press the func. /set button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Canon Powershot Pro1
I also have the same problem and I took it to the canon service center. They told me that I have to replace the whole lens kit the problem was with the shutter not closing properly thus overexposing the pictures
SOURCE: Camera takes white pictures in daylight
Sounds like over exposure due to the shutter not closing all the way. test video out. should work fine. shutter mechanism will need cleaning
SOURCE: I have a canon A520
The battery issue seems to be a problem with this model after 4 years, unfortunately you have to open and close the battery compartment to clear this error. This is not a permanent fix.
SOURCE: White photos canon A470? i have a canon
I had this problem too, I think it's the shutter problem, it doesn't close
when a picture is taken, therefore, causing the over exposed photo...I've sent it back to canon, still waiting for the reply...
Kevin - Malaysia
