HP ProBook 4510s Notebook Logo
Posted on Aug 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Quickplay not work in win7 64! - HP ProBook 4510s Notebook
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 68 Answers
  • Posted on Aug 14, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
68
Questions
0
Helped
8942
Points
207
Hello esamili, I'm sorry to say that Quickplay doesn't seem to be compatible in the 64 bit version of win7. you can try running the program in compatibility mode.
  • Right Click on the HP Quickplay Icon.
  • Left Click on properties.
  • Left click on Compatibility Tab.
  • In The compatibility mode Section click on the check box stating "Run this program in compatibility mode for:"
  • Left click on drop list.
  • Left Click on Windows Vista (Service Pack 2).
  • Add Your Answer
    Can't find the webcam
    Try this and see if it helps:
    1. Press the QuickPlay button c01270820.jpg (normally located near the display) to open the QuickPlay application.Alternately, click Start , type quickplay in the search field, and select QuickPlay when it becomes available to open the QuickPlay application.
    2. Click the QuickPlay c01270821.jpg Video icon, then double-click HP webcam in the Source column.
    I have a problem in using my webcam,its indicated that i need to turn it on.
    You need a program like QuickPlay or Muvee Autoproducer to activate the webcam. When in Quickplay, go to the bottom of the screen, select the icon with a camera, and then choose the device from the left-hand menu.
    Press the QuickPlay button (normally located near the display) on the notebook PC to open the QuickPlay application.
    Alternately, click Start , type QuickPlay in the search field, and select QuickPlay when it becomes available to open the QuickPlay application.
    Click the Video icon, and double-click HP webcam in the Source column.
    The input from the webcam displays on the screen
    1helpful
    How do i turn on my web cam on my new windows 7 compaq laptop?
    You use, Quickplay, To access QuickPlay, just press the "blue QuickPlay button" next to the power button. If it doesn't load QuickPlay, just do "Start" - "All Programs" - then you will see QuickPlay listed there. If you still can't find it just do a search, you will find the short-cut.
    Once launched QuickPlay, click on the 2nd icon from left (between DVD and TV icon), then double-click on "HP Pavilion WebCam" from the left side panel, then you will see the blue LED light lit and you should see yourself on the screen. (Double-click "yourself" to enlarge image)
    To take a picture or record video, just press the corresponding buttons on the top. (the red circle icon is for recording video (press "Stop" icon to stop recording), the camera icon is for, well, camera)
    Videos and pictures are saved at:
    Pictures -- C:\Users\Public\Pictures\My Snapshots
    Videos -- C:\Users\Public\Videos\HP Webcam
    Just go to:
    C:\Program Files\HP\QuickPlay
    and see if you have QuickPlay installed or not.
    If yes, then double click on "QP.exe", and that should bring up QuickPlay. And later you can make a shortcut to it.
    1helpful
    I do not use Quickplay and would like to disable the touchbutton
    go to control panel, add or remove program and simply uninstall Quickplay.
    1helpful
    I have a problem with my webcam sound. I recorded my assignment speech and when i try to listen to the speech, there was no sound coming out from the webcam. i tried everything and nothing worked. Can you...
    Hi chinonsobeau,
    First off, you to list the model number of your HP web Cam, as well as your OS, and the software you using to record your sound. I will assume that you have Quickplay which HP ususally send out with their web cams.
    To access QuickPlay, just press the "blue QuickPlay button" next to the power button. If it doesn't load QuickPlay, just do "Start" - "All Programs" - then you will see QuickPlay listed there. If you still can't find it just do a search, you will find the short-cut. If you still don't find it, then HERE is a place you can download it and use it. It also has instruction on how to use it.
    Or sometimes HP sends out Cheese, another camera software. You can download that HERE.
    These are the instructions for QuickPlay:
    I'm less familiar with Cheese, so I'll give you their website HERE to go to their support and they can guide you through their program.
    Anyway, I hope this helps,
    Don't forget to leave a raing,
    Thanks
    Mark
    Videos -- C:\Users\Public\Videos\HP Webcam user_offline.gif
    2answers
    Hp dv7-1132nr Quickplay touch button doesn't launch quickplay.
    i have same problem. Only wirelles button work. I dont know what to do? Is there any solution for this ? Is this hardware or software problem ?
    How to get my webcam works
    1. Press the QuickPlayc00865937.jpg button (normally located near the display) on the notebook PC to open the QuickPlay application. NOTE: If this takes you to DVDPlay instead of QuickPlay, then you are probably not using an HP Pavilion notebook and you do not have QuickPlay installed. You should skip this test and go to Test the webcam using YouCam instead. Alternately, click Startc00814574.gif , type QuickPlay in the search field, and select QuickPlay when it becomes available to open the QuickPlay application.
    2. Click c00865938.jpg icon, and double-click HP webcam in the Source column. The input from the webcam displays on the screen.
    3. Click Record in the QuickPlay window to record a short webcam file, and then press Stop .
      • By default, the file is saved in a public folder, and the date is used as the name of the video file. For example: C:\Users\Public\Videos\HP Webcam\webcam_20070228_1540.mpg .
      • The saved file can be renamed and moved for use by QuickPlay or other media programs.
    4. Double-click the name of the file in the playlist in the QuickPlay window to view the short Webcam file.
    5. If you can view this file, this concludes this test. You should now test with YouCam.
    If you have a third-part webcam, see HP Notebook PCs - Testing a Webcam in Vista with QuickPlay for additional information. Test the webcam using YouCam To verify that the webcam on an HP or Compaq computer that shipped with Microsoft Vista with Service Pack 1 installed is operating properly, perform the following YouCam test. This test verifies that the Webcam is working and can record or play video files.
    1. Click Startc00814574.gif , type you in the search field, and select Cyberlink YouCam from the resulting list. After a few seconds the program starts and the webcam image should be visible in the main viewing window.
    2. Click c01475672.jpg in the main control bar to record a short webcam file, and then press Stop .
      • By default, the file is saved in the Documents folder, in a subfolder named YouCam, with a generic name based on the date. For example: Capture_20080327.wmv
      • To navigate to this folder, click Startc00814574.gif , Computer , and then select Documents under Favorites, and then open the YouCam folder.
      • The saved file can be renamed and moved for use by YouCam or other media programs.
    3. Double-click the name of the file in the playlist in the YouCam window to view the short webcam file.
    4. This test verifies that the webcam is working and can record or play video files.
    I hope this helps you, I don't have the same operating system. You can find all the information you are looking for at http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01560721&lc=en&dlc=en&cc=us&product=3795310&lang=en#N565
    Can't run a quick play
    Quick play is a funny animal, first go to add and remove programs.
    Remove quickplay. Reboot unit.
    Next, google quickplay 3.7 and download the program.
    Next open the quickplay program and allow it to my a new folder.
    After quickplay has finished you will have a updated quickplay 3.7 or better and should run with no problems.
    Hope this has helped you.
    Quickplay button
    U need to install quick launch button software. Go to hp site and look for ur model related software from there download quick launch button (QLB). it will ask u to restart. hopefully it wil work.
    other way is go to this location u must have QLB in there.
    c:/swsetup/QLB
    How do i turn on my webcam
    Yes, you can use the WebCam through QuickPlay, and yes, it works under Vista.
    Have Fun! __________________
    HP Pavilion dv6000t CTO
    Microsoft Windows Vista Home Premium Build 6000
    Core 2 Duo T5600 1.83 Ghz / 2MB L2 Cache
    Top HP Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
