Question about Acer TravelMate 4200 Notebook
How to turn on my bluetooth on my acer travelmate 4200 ?
Posted by sasukezx12 on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: acer travelmate 2310 bluetooth driver
http://support.acer-euro.com/drivers/downloads.html
Posted on Feb 14, 2008
Anonymous
SOURCE: acer travelmate 240 linux bluetooth problem
I have an acer travelmate 240 running centos 5.It has bluetooth but I dont know how to install it.I need help.
Posted on Oct 20, 2008
Anonymous
  • 93 Answers
SOURCE: acer travelmate 5520 bluetooth not working
Make sure there is a Bluetooth device physically installed in your laptop, it could be check from your purchase paper...
Posted on Nov 13, 2008
Anonymous
  • 54 Answers
SOURCE: How do I re-format Acer 4200 TravelMate hard drive?
Windows Reinstallation Disk option:
Insert Windows Reinstallation disk into tray, Boot to CD/DVD-ROM by pressing F12 at initial boot screens, delete existing Windows partition, re-create partition, and then follow steps to reinstall Windows. This will lead you to an option for formatting hard drive. I recommend choosing the full format versus the quick, from this point you can let windows install, or just shut the computer down when the format finishes. You will have to watch the progress, though, if you don't want the install to commence.
Boot disk option:
For XP, 95, 98, or ME, follow the instructions at this MS article page. It will walk you through creating a boot disk that will allow you to format.
You will need a floppy disk or CD
Posted on Apr 03, 2009
SOURCE: acer travelmate 5520 cant turn on bluetooth
Please vist the link below to determine if the computer has bluetooth
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire1300/Aspire1300faq37.shtml
Posted on Mar 18, 2010
My acer travelmate 4200 starts up and then shuts off
Try another Cord/Charger with the EXACT same power specs. Have you cleaned the fan, vents, heatsink recently? Do you get to any screen? BIOS setup? Boot Menu? Has the AC jack been damaged due to pulling on the cord?
Ports on acer travelmate 4200 not working?
sounds like you may have driver for usb ports missing. check in device manager and see. if so simply reinstall drivers
Need video controller driver for travelmate 4200 acer laptop or at least know what the name of the driver is.
Hi Friend, In this case I would recommend you to follow the below link that will have all the drivers listed for Acer Travel mate 4200 along with the Operating system.
http://support.acer.com/us/en/product_support.aspx?tab=1
I would suggest you to please install the Chip-set drivers first and then the Video drivers
Please let me know if it was of some help? Thank you.
Cmos battery acer travelmate 4200
most times the battery is located under the ram chips
there is also 2 pins that can be shorted together that will reset the bios password if you cannot see the battery when opening the ram door.
please rate my help++++Thanks for using FIXYA
I have a broken cd/dvd drive on travelmate 4200
Should be,just make sure they have the same connector on the same side. Also, look at the front bezel & see if there's any interference after it's in.
3helpful
Where or how do I find the wireless switch?
On the front of the laptop there is a Bluetooth button, and a wireless button.
On the front edge of the laptop, starting from the Left;
Speaker, Bluetooth button, Wireless button, Power indicator light, Battery indicator light, Microphone-In jack, Line-In jack, Headphones jack, Speaker.
The Bluetooth button has a light in the middle of it. If the light is on, Bluetooth is enabled.
If it is on, turn it off. (Push the button in, let go. The light should be off)
The Wireless button, also has a light in the middle of it. If the light is on, wireless is enabled. Be sure it is on.
During cleaning the virus out, the Bluetooth, and wireless LAN driver may have been corrupted.
Here is Acer Support, and the Drivers Download page,
http://support.acer.com/drivers_download.aspx
On this page you are going to find the wireless LAN drivers, for your Acer Travelmate 4200 PC Notebook.
1.In the Select Product Family box, Left-click on Notebook.
Wait a second, the next box will come up.
2.In the Select Product Line box, Left-click on
Travelmate.
3.In the Select Product Model box, scroll down, and left-click on Travelmate 4200.
Use the blue bar, on the right side of the Driver file name box, and scroll down.
You will see there are 3 wireless LAN drivers listed.
1.Wireless LAN - Atheros
2.Wireless LAN - Broadcom
3.Wireless LAN - Intel
Left-click on the orange box, to the left of the appropriate wireless LAN driver you need.
(Orange rectangle with down arrow pointing to a line)
A small window will come up. There is a circle to the left of - Open with,
and a circle to the left of - Save File.
Left-click on the circle to the left of - Save File.
Now go down to the right, and click on OK.
This file will either go to your Documents folder, or it will go to your desktop screen.
In either place, when you see the file name, Double-click right on it.
The Installation Wizard will come up.
Click on Next, Next, and Finish.
(Bottom of each window)
Restart your computer.
To know which wireless LAN driver you need, (Atheros, Broadcom, or Intel), go to Device Manager.
1.Left-click on Start, (Vista logo button)
2.Left-click on Control Panel
3.Left-click on System and Maintenance
4.Left-click on Device Manager
(If you are prompted for an administrator password, or confirmation, type your password)
When Device Manager loads, look at the file tree before you.
Go down to - Network adapters, and left-click on the + sign to the left.
Across from wireless LAN you will see the name.
Travelmate 4200 touchpad mouse doesn't work.
go to the computer hardware point or servicestation.
Won't connect to bluetooth printer
Sir,
This laptop does not ship with a bluetooth device. The button is available on the casing because Acer do not have separate casings for laptops without Bluetooth. Also, an opton for adding a bluettooth chip is available with Acer at a cost though.
Acer TravelMate 4200 Notebook Logo
Ekse
Steve Sweetleaf
Steve Sweetleaf
