SOURCE: BURN HOME VIDEO TO DVD
Assuming that your camera is not equipped to interface directly with your PC, here are the steps to take to get your videos from VHS to DVD:
- Purchase a video capture device.
A cursory websearch garnered once for $50.00 here:
ADS Tech Video Xpress
http://www.pcmag.com/article2/0,1759,1902901,00.asp
- After setting the device up, use the bundled software to convert the video file into DVD format and then burn to disc, using your favorite burnig software. Be sure that it is burning in the VIDEO_TS/AUDIO_TS format and not just copying the .avi to the DVD.
If you would like for me to elaborate on anyt of these instructions, please don't hesitate to contact me directly at [email protected]. Good luck and, again, let me know if there's anything else I can do. I think you'll be just fine though as this process is fairly straightforward...just time-consuming.
SOURCE: need manual for using the JVC GR-AX201A compact VHS camcorder
Please download user manual of GR-AX201 from JVC Support.
SOURCE: WE NEED THE OPERATING MANUAL FOR THE JVC COMPACT
The operating manual could be downloaded from here
http://resources.jvc.com/Resources/00/00/91/LYT1519-001A.pdf
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: I want to get the video on my JVC GR-AXM17U VHS-C
Software, Cables. Thats about it. There are a couple of ways to do it. If your JVC has a USB port & cable then using the software that came with the camera, OR downloaded from the manufacturers web site, install that, THEN connect the camera up, most likely it will show up as a "Drive" then you should be able to simply Copy & Paste your files as normal. Then once on PC you can manipulate them however you want. IF you have Composite Video & Audio OUT on JVC, and you have some method of getting Video & Audio INTO your PC, then you can also use this, Plug it all in, start your "Recording" software, then Press Play on JVC, You can get USB Video input dongles, 7 or, some video cards allow Video IN too.
Testimonial: "Thanks! That will work"
