To hard reset your Nokia X3 you just have to press *#7370# and
press Dial. The phone will request the security code that is by default 12345.
Please be aware that you will loose all the data in your phone, so you should
backup all relevant information.
If you want to soft reset your Nokia
X3 you need to press *#7780# and then Dial. The security code is 12345.
Once you complete this, your phone will come back to factory settings, but you
will not loose personal data. Anyway it is recommended to make a backup before
performing any of the mentioned procedures.
Buka kode nokia x3
SOURCE: my nokia x3 memory is
First remove the memory card...located at the left side of your phone. After removing your memory card, Go to your phone's menu, then select the settings then find the Restore Factory Settings, then there are two option restore settings only and restore all, select the restore all then your phone will ask for a code, the default code is 1234, if you have your own code then enter your code, after that select OK then your phone will restore to its original settings. but be sure to back up you contacts. Goodluck.
SOURCE: nokia x3 phone keypadwasnot warking
please your slider belt is not working so your key pad not working
