Question about Metra Ford F 150 Truck 1999
1994 Ford F-150 V8 305 (5-Liter). I just installed a new battery. Truck STILL will not start. I traced the main NEGATIVE wire from the battery post, down into the engine compartment and found it connected to NOTHING! Dangling free! I can't see or feel where it SHOULD be connected. |Could you tell me please?
Posted by clarkcook on
islandcuts
    New Friend:
  • 3 Answers
It could be your starter or is it a stick your automatic if you dont mind me askibng you can email me back at [email protected] thanks Dennis and i can try to help you
Posted on Aug 14, 2011
I have a 1984 ford e-150..new battery...alternator tested good 2 times...new v
if you trace the main wire from alt to battery and still no charge,then you need a new alternator,it will not charge under load
Apr 28, 2015 | Ford Cars & Trucks
Would the firing order be the same on a 98 ford 150?
Hi Joann:
About what engine sizes...
Ford Truck F 150 4.9 liter L6 VIN "Z"
Ford Truck F 150 5.0 liter V-8 VIN "N"
Ford Truck F 150 5.8 liter V-8 VIN "H"
Ford Truck F 150 5.8 liter V-8 VIN "H" Lightning
Confirm us.
Dec 26, 2011 | 1993 Ford F150 SuperCab
How to install an alternator in a Ford F 150, 4.6 liter engine extend a cab truck
disconnect the negative battery terminal. Disengage the drive belt from the pulley. disconnect the wiring from the alternator. remove the mounting bolts (and bracket if necessary). remove alternator. reverse for install
Jun 19, 2011 | Ford F-150 Cars & Trucks
1989 Ford F-150 short bed, 6 cyl.-Tried to start and it was completely dead. Battery is only couple years old. I checked to see if lights or inside lights were left on and they were not. Hooked up battery...
Check your ground wire from the battery to the starter...there was a hold down clip theat had rubbed thru the wire coating...left side of the engine. My truck would die...hit the wire and the hood light would come on but wouldn't start even though I knew the battery was charged. Replaced the negative battery cable and all is well, atleast with that issue.LOL
Aug 30, 2010 | 1989 Ford F 150
93 to 95 Ford F-150 V-8 engine....firing orders!
Here are the firing order diagrams for those engines and I hope that they will help you solve the problem that you are having. For some reason Ford has listed the same firing order for both engines starting in 1995.
1993 5.0 liter engine firing order.
1993 5.8 liter engine firing order.
1994 5.0 liter engine.
1994 5.8 liter firing order.
1995 5.0 liter engine.
1995 5.8 liter engine.
Jun 16, 2010 | 1993 Ford F150 SuperCab
How to change knock sensor on 4.9 liter 1989 e 150
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disconnect the wiring from the sensor.
  3. Remove the sensor from the cylinder block.
To install:
  1. Attach the KS to the cylinder block.
  2. Attach the electrical connector to the sensor.
  3. Connect the negative battery cable.
May 06, 2010 | 1989 Ford Econoline
Ford 2003, F250 Desel, 7.3 Liter Head lights
first thing i would check is the wiring were the plow wiring is spliced in at this is most likly the culprate. or you may have a bad multi function switch in the steering column
Jan 02, 2010 | 2003 Ford F250 Super Duty Crew Cab
1988 ford f-150
i was able to loosen the switch and slide it up the shaft and use wire ties to hold it to the top of the shaft. no more problems. the only down fall is that the truck will now start in gear.
Jul 30, 2008 | 1988 Ford F 150
Alternator not charging
Hi
If you have a volt meter, set it to volts and hold the negative probe to the alternator body and the positive to the battery positive. If you don't get battery voltage then the alternator isn't grounded and the probable cause is the main engine ground cable either breaking or coming loose.
Very best regards
Geordie
Jun 10, 2008 | 1982 Ford F 150
Metra Ford F 150 Truck 1999 Logo
65 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
