SOURCE: app error 523 reset
You can try a soft reset, hold down left ALT, right Shift and delete simultaneously for a couple of seconds.
If that isn't working or you don't get the timing right. You can try resetting by turning the device off, remove the baterry for 1 minute or so, reinsert and turn the device on.
The error should have disappeared, if not let me know any other issues you may have noticed.
SOURCE: black berry curve app error 523
error 523 reset means a "System process died" You'll need I would reload the entire handheld OS again.
1. Install the software from the CD (that you received with the device), or download it from the service provider (AT&T).
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
