Question about Tilia FoodSaver V2240
I have a Foodsaver 2840 that will vacuum and seal, but not seal alone. The manual button does not work (though it worked earlier today). I have tried everything. Any hints?
Posted by donnaj615 on
Curtis Sewell
  • 7,482 Answers
Hi donnaj615...
Start the vacuum and then immediately click on the seal button...
I have a 750 that does the same thing...
Please take time to rate me
Posted on Aug 13, 2011
Sealing button blinking when i push any of the other buttons and no sealing and vacuum working
Hi, it might be a problem with the sealing pump or something electric. If you are within the US or in Canada please contact us with your serial#: 1-888-956-6866 X: 234 OR X: 235. Eurodib
Feb 05, 2014 | Tilia FoodSaver V2240
2240 unit vacuums but won't go into seal mode. if the seal button is manually pushed, it will then seal but the vacuum is lost
I am having the same problem, it is like the heating element for the sealer is broken.My unit actually will NOT seal if I push the manual seal, but the vacuum works.
Feb 24, 2013 | Tilia FoodSaver V2240
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Foodsaver V845 is not sealing? vacuums okay, but won't seal bag.
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Jan 24, 2011 | Tilia Foodsaver V835 Vacuum Sealer
Vacum works heatseal does not seal can i replace seal
Sealing always tends to be the problem with FoodSaver because during the course of normal wear and tear, the sealing strip and wire will naturally need to be replaced.
You can get replacement heating wires and strips at www.elementandteflon.com
We started out selling just replacement parts for heat impulse sealers but we kept on getting customer requests for FoodSaver parts so we've added that section to our website.
Dec 14, 2010 | Tilia Foodsaver V835 Vacuum Sealer
The V2240 does not seal or vacuum at this particular step. The motor runs, the unit buttons are working but the vacuum, sealing action does not work..... Any ideas ..... And yes It was plugged in !
It's possible that liquid is getting into the sealer or the seal is dirty. Here's a link for a pdf that explains possible problems and solutions.
http://www.foodsaver.com/Manuals/MANUALS/T000-32030_44_65900646.PDF
Dec 11, 2010 | Tilia FoodSaver V2240
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
May 17, 2010 | Tilia FoodSaver V2240
Tilia FoodSaver V2240 Logo
297 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Sheldon Dedek
Tom Chichester
Terry
Terry
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
