Hello there, the only place you can get replacement wahl chargers are from their service centers which are spread out around the US. Here is a Link to all their animal equipment service centers which are across the US. Also you can check the user manual and get the charger specifications from there walk into any electronics store and have any adapter with the same specifications given to you to replace the charger. This should cost you less money and time.
Hope this solution has been helpful?
Thank you for visiting FixYa.
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
hope this helps
