Take a look at this webpage. It has a really inexpensive canoe stabilizer you can build at home.
The
FixYa Team
Richard
Roth
Something that is cost effective. Sounds like you got the right idea. Some PVC piping maybe.
FixYa Support
This is something that worked for me, but I have no idea if it was the right way to do it or not.
I first, figured out the shape that the bottom should be in and then cut 2 each 3/4" plywood pieces, sealed it, sealed it again and then you guessed it sealed it again. Then I use a kerosene heater to heat the skin of the boat to expand it as much as possible, and then insert the two plywood pieces while the heat was still applied. I drilled four holes for each piece and then used rubber grommets on the inside and outside and screwed into the plywood to hold them rigid. Then took the heat away and let everything cool down. The skin really tightened up around the plywood strengtheners more than I thought it would, and made it very stable.
A word of caution: Wear gloves and long pants because the metal skin gets very hot and I wore the marks on my knee and hand for several weeks. And the skin has to be very hot for this to work very good.
Yes, I screwed through the skin and I placed the plywood strengtheners equal distance to cut the canoe into three equal parts. And you don't have to take it completely to the top. I took mine 3/4 and later modified it to 1/2 way up.
I sealed it with marine spar varnish, either 3 or 4 coats and put a coat on about every two years to maintain it.
Yes, that is where I got my original idea! If it hadn't of worked I was going to junk the canoe because it was so badly warped from the sun at altitude that it was very unstable. I just had to modify the size appropriately.
Your welcome.
I'm not quite understanding all of this.How and where and where did you put the plywood pieces?Am I understanding you right that you screwed through the skin and left the plywood in place in the canoe?
What did you seal it with? a varnish of some kind or a oil based paint.
My brother built a cedar strip canoe. would the plywood pieces be similar to the ones used to mold that?
Thanks guys for all the help. Chuck
thanks for the help didn't see this post til today I might try a combo both our ideas.
