Question about Nikon D60 Digital Camera
Hi, I have a Nikon D60. Somehow I locked aperture at highest number. Even with Manual setting, it does not let me change aperture! Please help
Posted by tartepink on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
The lens is supposed to be locked at its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as on a lens without an aperture ring. For example, in aperture priority mode (A), simply turn the command dial. In manual mode (M), hold down the exposure compensation button while turning the command dial.
That was for a lens with the electronics to communicate with the camera. If you have a purely mechanical lens, you must shoot in manual mode and control the aperture by turning the ring on the lens. There should be a small orange slide near the aperture ring, Slide it toward the front of the lens to unlock the ring.
If you need more help, please feel free to reply to this post. Please specify the lens when you do.
Posted on Aug 13, 2011
  • Ahmed Sep 01, 2012
    @K_akima: I have read almost all your solutions regarding the fEE/aperture ring problem. I am using a Nikon D60 and trying to attach a 28-300mmD Aspherical IF lens to it. I have tried everything, the ring is set at 22 and locked, cleaned the contacts etc but the "lock lens aperture ring to minimum" will not go away. It is displayed over the camera settings display and the command wheel does not work at all. I can only access the MENU and no other button is working, on any exposure mode! My original 50 lens work perfectly. Was wondering if you had encountered this before? thanks in advance!
Quantaray lense wont work on nikon D50
David -
The lowest setting is the highest number; f22 is lower than f4. It's little counter-intuitive, but the lowest setting means the least amount of light - or the smallest aperture opening - not the numerical "f" value of the opening.
Simply twist the aperture ring until the highest value "f" number is selected. Many lenses have a small tab or latch to lock them in this position - if yours does, you can use it to prevent this from happening again. You would use a command dial on most camera bodies to electronically change the aperture opening.
May 16, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
I bought an older 28mm nikon lens for my d60. when i try to rotate the apertrure ring, the d60 screen says that the aperture must be set to the highest setting. am i stuck with this aperture...
Set the aperture to its smallest opening (largest f/number) and lock it. You can control the aperture from the camera, the same way you do it on a lens without an aperture ring.
Apr 04, 2011 | Nikon N50 35mm SLR Camera
I HAVE A NIKON D60 CAMERA. WHEN I TURN ON THE CAMERA AND PUSH THE BUTTON TO TAKE A PICTURE THE BUTTON WILL NOT LET YOU TAKE A PICTURE ( IT SEEM TO BE LOCKED ) AFTER SOME TIME OF TURNING THE CAMERA ON AND...
Some reasons for this may be the Memory card is full, locked, or not inserted,or
Flash is charging.
Camera is not in focus.
CPU lens with aperture ring attached without locking aperture
at highest f-number.
Non-CPU lens is attached: rotate camera mode dial to D
hope this helps.
Jan 01, 2011 | Nikon D40x Digital Camera
I have a Nikon D60 and have just bought a 50mm AF 1.8 D lens but find I can only use the aperture setting at 22. Is that right ?? why can't I use the other aperture settings ??
The D60 camera sets and triggers the aperture that you have selected (or the camera has selected if in auto mode) and sets the aperture as you take the picture. Moving the aperture ring on the lens will not work, in fact once you move it from the f22 position the camera will stop or possible show and error. on my older Nikon AF lenses there is a small lock to lock the aperture ring in the lowest position when mounted on a digital camera, it is found near the f2.8 side of the aperture ring. when you want to set the apertures manually, you put the camera in aperture or manual mode and set the aperture you want by moving the the rotating wheel on the grip part of the camera. the aperture you select will show in the window, you do not have to move the ring on the lens,it must remain the f22(highest numerical) position.
Oct 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
The 300mm lens would not work when attached to the
Which 300mm lens? Does it have an aperture ring? If so, you'll have to turn it tothe smallest aperture (largest f/number) and lock it if it also has a lock. You control the aperture the same way you do so on any other lens, by turning the command dial (possibly in conjunction with holding the aperture button).
May 11, 2010 | Nikon D60 Digital Camera
I use first time nikon d60.
it would depend on the lighting. you can lower down your shutter speed, or change the white-balance or aperture on the camera. make sure that your camera is set on manual. hit me back on the results.
Jan 30, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Our Nikon d1x won't take a picture. It gives me an FEE type of error and the battery flashes.
The blinking FEE message means the aperture ring is not set to minimum aperture (highest number). Turn the aperture ring to the highest number, and then find the aperture lock -- either a little slider or a button you press and turn. That will keep it from accidentally changing again.
Dec 31, 2008 | Nikon D1X Digital Camera
FEE blinks
Set f stop ring ( aperture ring ) on the lens to highest F stop number ( 16 ) and lock in position. This will get of fEE massage.
Jan 21, 2007 | Nikon N60 35mm SLR Camera
Nikon D60 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Nikon Camera Expert? Answer questions, earn points and help others
