Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Did you reolaced battery that evening, if you did then try holding the battery door tight and the turn it on. If this will solve it it means that there is a play in battery door that happens very often if someone is not careful enough while replacing battery or merory card.
Hello, You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
Hi There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
KEN,
I HAVE LOCATED THREE REPAIR SHOPS THAT WORK ON CANON AND GIVE FREE QUOTES. I DO NOT ENDORSE ANY OF THESE, BUT PASS THEM ON FOR YOUR INFORMATION. AS FAR AS I KNOW THEY ARE RESPONSIBLE. THE WEBSITES ARE BELOW. I HOPE THIS HELPS! GOOD LUCK! IF YOU NEED ADDITIONAL HELP,REPLY TO:ARCLIGHT1217
send it to us most likey it is a blown fuse. we can repair for 85.00 worst case 125.00 depending on the issue. but 125.00 is the very worst case normally it is only 85.00 send it in for a free diagnosis.
