LG LDF6810 Built-in Dishwasher Logo
Posted on Aug 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kitchen aid dishwasher KUDS03STSS2 does not drain...any assistance would be appreciated.
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on Aug 15, 2011
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
10835263
Points
101584
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
My Kitchen Aid dishwasher KDS16 gets water backing up onto the bottom of the dishwasher?
Make sure drain hose has a high loop higher then sink and change you’re check valve which is part of drain hose
Sep 29, 2020 • Dishwashers
How do I remove the suds after having used regular dishsoap instead of dishwasher soap?Kitchen aid dishwasher
you will just need to run it a few times. I know of no way to kill bubbles except to dilute them.
My kitchen aid dishwasher will not drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Kitchen Aid Dishwasher does not drain completely
loop the drain hose up under the sink higher than your sink drain.
Kitchen aid dishwasher not draining....help
heatman101
1helpful
Also have no manual for this dishwasher
Hi
Thanks for using FixYa. You can download the user manual for Kitchen Aid Dishwasher KUDR01TJ from the following link---
Kitchen Aid Dishwasher KUDR01TJ User Manual
Please do rate the solution and revert for further assistance.
Thanks
Rylee
2helpful
2answers
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
1helpful
2answers
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
5helpful
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 • Dishwashers
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
