Question about U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613)
How do i set up WEP/WPA security on th eUSR 5461
Posted by uvegotnel on
Reparatii PC - Service IT
  • 2,574 Answers
Visit the link below: ....www.usr.com/support...
Posted on Aug 13, 2011
The access point's security settings are not supported by the nintendo DS
This means you've got a WPA/2 security connection on your router/access point, whereas the Nintendo DS only supports WEP or open encryption.
You can:
1) change your security from WPA to WEP on your router
2) Purchase a used nintendo wifi stick
3) Set up a second router or access point with WEP security specifically for your DS
May 16, 2011 | Nintendo DS Lite
What is the wep password
The encryption key secures your data from unauthorized access.
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 30, 2011 | Linksys PAP2T
The access point's security settings are not supported by the Nintendo DS
WEP and WPA are types of security that are used to protect home wireless networks. WEP is the only security setting that works with the Nintendo DS and Nintendo DS Lite. WPA and WEP are both compatible with the Nintendo DSi. If you are not sure how to find your router's WEP or WPA Key or if you have problems entering it into your Nintendo DS, try the following tips:
so if your wifi is WPA. you wont be able to use wireless
but if your wifi is WEP you can.
WEP is not recommended because it is not secure. Easy to hack
Mar 20, 2011 | Computers & Internet
What's the difference between WEP and WPA? What should I pick?
WEP is a weak securtiy protocol that is outdated and can be easily broken
WPA is a newer security protocol that is much harder to break with AES encryption
WPA is always recommended mode for operation over WEP.
Use WPA2 which is latest version if it is supported by device.
Mar 12, 2011 | Belkin N1 Wireless-N Wireless Router
How do I secure my network
etting up wireless security is the easiest way to prevent other people from using your wireless internet connection. Your Linksys router supports three (3) of the most commonly-used wireless security types WEP, WPA and WPA2.
This article will explain the difference between WEP, WPA, WPA2 and how to set up each of them.
Nov 06, 2010 | Linksys WRT160N Wireless Router
Set up a non wep password
Hi Friend,
Please follow the steps;
1.Open the router page(192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blank)
3.Click Wireless and then fill the sections as mentioned:
Wireless-Enabled
Wireless Netowrk Name-As per your choice
Wireless Channel-6-2.442GHz
Wireless SSID broadcast-Enabled and click Save settings
4.Click Wireless Security and fill the sections
Wireless Security-Enabled
Security Mode-WPA pres-shared key (as you want non wep password)
WPA Algorithm-TKIP
WPA Shared key-Minimum 8 and maximum 64 digit password
Group Key Renewal-3600 and click save settings
Turn off the router for 30 seconds and turn it on after that. Now you have a non wep secured network
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
Is the PIN on the bottom of the router the same as the WEP or WPA?
WEP or WPA are the types of wireless security. If your wireless network is secured then there will be a password on the network that is called as wireless network key or passphrase ( WEP or WPA key ). PIN number is different than WEP or WPA.
To check the wireless network key ( WEP / WPA) you will need to access the router settings page.
On that page , you will find all the settings of the router.
Apr 29, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
Laptop doesn't recognize printer[c-7280]
For wireless security you can select WEP or WPA security. Some are specific lengths but within reason you can choose your own. Set in on the router first then on the computer. You may need to set up the router with a wired connection
Jul 08, 2009 | 2wire 2700HG-B Router (2700HGB)
Panasonic cf-50 problems to connect wireless wpa personal
If the wireless card is an old model it possibly won't support WAP encryption. The wireless router most likely supports both WEP and WAP encryption.
WEP is not as secure as WAP so use the highest bit encryption that is available to you.
May 07, 2009 | Panasonic Toughbook 50 Notebook
I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure Access list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
  • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
Configuring WEP:
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  4. Under Security Options, Select WEP (Wired Equivalent Privacy)
  5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Apr 27, 2009 | NetGear WGT624 Wireless Router
U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613) Logo
70 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Barbat Nae
Barbat Nae
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
