Washing Machines Logo
Posted on Aug 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dependable care model no LAT9806BGE Dependable care Heavy duty Now very noisey when spin drying.Have to stop machine. Viabration bad in the tub. Belts have been replaced. thanks
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Aug 13, 2011
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10842474
Points
101584
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
I have a Maytag Dependable Care Heavy Duty dryer and it makes an awful noise when it runs, also it isn't heating what should I do?
the knocking is either a belt that is going or one of the wheels is broken(they ride on three or four wheels). and those fixes are fairly inexpensive. but if it is also not heating, that can be inexpensive or not. maybe a new one, or fairly new via craigslist. how old is your dryer. over 10-12 years, maybe replace this one
1helpful
Maytag model lat 9605 aae fills with water but want agitate or spin out but works fine on delacate cycle thought it was timer put one on still doing the same thing
replace the motor brushes this is common it wont spin or do main cycles but easy go it does is worn brushes
take one and and check the lenght if its less than 50mm replace them
when they get shorter the motor draws more standing current etc running hotter so....
also check the vacume switch and for and rubbish inside the drum skin
Hoover 750 lc heavy duty macking noise whene spinning dry
Possible drum bearing. Check for any knocking by turning drum by hand whilst empty.
1helpful
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
3answers
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
I have a model #LAT8714AAE Dependable care plus Heavy duty 2 speed super capacity washer. I replaced the timer and the unit will not start when dial is turn to 12 ( it will not start filling up) but if you...
CHECK THE FUSE ON THE LID SWITCH BELOW THE TIMER. IF ITS BLOWN YOU NEED THE LID SWITCH ***.SOMETIMES EVEN IF ITS NOT BLOWN THE SWITCH IS BAD
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
3helpful
2answers
Kenmore heavy duty energy star will not drain or spin
the pump is plugged gain axcess to the pump and remove the restriction get your wet/dry vac remove the water in the tub and have handy also a small bucket to once you remove the cap to remove the object then it will go into spin
Washer stops spinning in the middle of the spin cycle
Doe,s the water come on when it stops, it may have something to do with the balance of the washing load, if the water comes on it,s trying to rebalance it self.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
