Use a small torch and look inside the game slot. It is most likely that one of the contact pins has been bent and is not macking contact. If any pins look mor bent than the others you may be able to bend it back into place. Remove the battery before you try any repairs (the battery is under the battery cover on the bottom of the DSi). After removing the battery, use a suitable tool such as a small screwdriver or an unbent paperclip to gently bend the pin back to the same position as the other pins. If the pin is too far bent to be repaired, then the game slot can be replaced but this requires desoldering of the game slot and this is not a task for a novice.
