Question about Pioneer DV-C503 Multi-disc DVD Player
It wont load or play cd's or dvd's and the door opens and shuts right away. It has progressively gotton worse so now it wont play at all. when you put in a dvd it says loading then it just stops. please help!
6ya staff
SOURCE:
Anonymous
  • 7 Answers
SOURCE: dv-c503 pioneer dvd player
the magic eye on the door opener in been obtruated by something .. like a small object stuck on a cd or someone might just open the door and let something in it .. stuck on the slidetrack ..and interfer with the sensor .. maybe kids???
Posted on Dec 31, 2007
Anonymous
SOURCE: DVD WONT PLAY
same problem-put it in for repair -advised dvd tray is a one piece assy and it was faulty-requiring full assy rplcmnt @plus£150
nuff said=bought a new dvd
Posted on Feb 23, 2008
Anonymous
  • 624 Answers
SOURCE: pioneer xv htd520 won't play dvds
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Dave
Posted on Dec 12, 2008
SOURCE: dvd door will not stay shut when dvd is loaded.
check if the trayer got a belt and change it ,is located under the tray
Posted on Oct 06, 2009
ric2k06850
Isaac Rene
  • 72 Answers
SOURCE: I have a LG DR389
try to buy a disc cleaner it might be dirty and reinsert the same DVD. Hope this info help you resolve your problem
Posted on Jun 07, 2011
Disc error
it might have died and gone to dvd heaven
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jul 20, 2012 | Sony (RDR-HX710) DVD±RW Dual Layer...
Acer dvd drive ejecting all time wont close
assuming that drive has nothing in it right? is suspect that your bios is looking for the installation cd to run from and it opens the door and waits until it's inserted has this acer worked prior to this happening?
May 21, 2012 | Acer Aspire 5732Z-4855 Notebook
My sony progressive scan 5 dvd/cd changer door won't shut, first it wouldn't open, thej i used a small screw driver, and pried it open, then it open then won't shut?
This is a loader mechanisn fault. Mithe be eiter to a loose loding belt, or defective loading gear wheels.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
May 17, 2012 | Sony Televison & Video
Zenith dvd/vcr model ABV341 DVD WON'T STAY IN TO PLAY...VCR WORKD FINE
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
Apr 04, 2012 | Zenith Televison & Video
I have a LG DR389 dvd recorder which is not loading and ejecting the dvd's properly. This has got progressively worse and now will not open the tray at all.
Jun 06, 2011 | LG Televison & Video
My LITEON 5045GDL+ dvd drawer wont open.
HI, you have two issue here. the load motor is malfunctioning. this is causing the door open and close feature to lock up. this motor is connected to the gear assembly. it should be replaced soon. the second issue is the optical lens assembly. this len assembly has failed. the laser is burned ut. this is causing the no play issue.
In conclusion, i recommend replacing the optical len assembly and the load motor as well. this will fix this issue. try not to force the door open often, this Will damage the loading dock gears.
Jun 18, 2009 | Televison & Video
DVD player no longer plays DVD's that I KNOW played on it before.
yes, Lazer wont aline to read, they get progressively worse, sometimes intermittent, if that is the case then you will need a whole new internal cradle. maybe time to get another one. the Yeti
May 20, 2009 | Televison & Video
Fisher 143a CD Changer
HI...
You wont be able to play any new format CDs on an old Fisher or any other older make . It 's the internal decoder logic that's needed. And older players dont have it.
As far as top-loaders..Do a websearch . I dont know of any.
Jan 27, 2009 | Jwin JK-777 Nostalgic Stereo System with...
Pioneer DV-C503 Multi-disc DVD Player Logo
57 people viewed this question
Top Pioneer Televison & Video Experts
Marvin
Marvin
Ekse
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
