1. My Computer Hope this helps
2. Right click on WD SMART WARE
- Click on "Explore" or
"Open"
and then double click on "Unlock.exe"
and input incorrect
passwords until you get an error stating to remove your hard-drive.
then open
up the "WD SMARTware" program
and it will ask you if you would like to
re-format the drive. ;D this will format this drive all data will be lost
or
is this your primary hard drive or just a hard drive used for storage
You could try this software it sounds
pretty good although I have not used it so I am unable to direct you on how but
it reads as though it has a password reset tool as well as windows password
cleaner and a blank the password utility on any user that has a valid account
on windows system and many other tools you might find helpful
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Dr.Freeware System Utilities which includes
data recovery software, data backup, password reset tools for Windows helps you
to maintain your system. Dr.Freeware is freeware, you can download and use it
for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT,
UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB
Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista
/ 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file
system is damaged, has lots of bad data blocks)
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local)
account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
If you want to remove the smartware password and keep all data, you may check this post on one repair and recovery blog, it might be helpful, this post shows the steps to remove the smartware password: How to Remove WD Smartware Password
How to remove hhd sata0 password i forgotten please help me
you will have to
contact the phone provider with your details and supply proof of your ID
eg:passport or motor car licence or registration no if this is what you mean by
breaking the security code
hope
this helps
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0 also you might try
http://majorgeeks.com/Bios_d235.html
Save, delete, and restore your BIOS settings
or http://majorgeeks.com/download.php?det=5710
you will have to burn it to a disk as an ISO
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
hope this helps
