Canon MV730i Mini DV Digital Camcorder Logo
Posted on Aug 13, 2011
The led screen is not working all the index comes up but when you record the screen is blank it records the sounds but no picture its the same through the view finder canon mv730i
Anonymous
Level 1:
Genius:
  • Contributor 1,812 Answers
  • Posted on Aug 14, 2011
Anonymous
Contributor
Level 1:
Genius:
Answers
1812
Questions
0
Helped
251551
Points
49
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
1helpful
Hi, i have recntly been given a canon mv5 camcorder, however, when I switch it on and start recording all I can see is a blank screen or a blank viewfinder. Sound can be heard during playback but it...
the damge could have occured to the lens gears inside of the cam, try to tap it while recording, very gently, its very fine ..other options is to reset the systen unit again and check..for further info check out this link.... http://www.canon.co.uk/For_Home/Product_Finder/Camcorders/Digital/MV5/index.asp
Oct 25, 2009 • Cameras
1helpful
I have a problem with my webcam sound. I recorded my assignment speech and when i try to listen to the speech, there was no sound coming out from the webcam. i tried everything and nothing worked. Can you...
Hi chinonsobeau,
First off, you to list the model number of your HP web Cam, as well as your OS, and the software you using to record your sound. I will assume that you have Quickplay which HP ususally send out with their web cams.
To access QuickPlay, just press the "blue QuickPlay button" next to the power button. If it doesn't load QuickPlay, just do "Start" - "All Programs" - then you will see QuickPlay listed there. If you still can't find it just do a search, you will find the short-cut. If you still don't find it, then HERE is a place you can download it and use it. It also has instruction on how to use it.
Or sometimes HP sends out Cheese, another camera software. You can download that HERE.
These are the instructions for QuickPlay:
Once launched QuickPlay, click on the 2nd icon from left (between DVD and TV icon), then double-click on "HP Pavilion WebCam" from the left side panel, then you will see the blue LED light lit and you should see yourself on the screen. (Double-click "yourself" to enlarge image)
To take a picture or record video, just press the corresponding buttons on the top. (the red circle icon is for recording video (press "Stop" icon to stop recording), the camera icon is for, well, camera)
Videos and pictures are saved at:
Pictures -- C:\Users\Public\Pictures\My Snapshots
Videos -- C:\Users\Public\Videos\HP Webcam
I'm less familiar with Cheese, so I'll give you their website HERE to go to their support and they can guide you through their program.
Anyway, I hope this helps,
Don't forget to leave a raing,
Thanks
Mark
Videos -- C:\Users\Public\Videos\HP Webcam user_offline.gif
1helpful
2answers
Camera flashes two times, but will not record a picture
this sounds like a problem with the sd card either being corrupt and needing formating or being to large. if made in 07 or older it takes 512 mb sd card max if in 08 or newer it will take up to a one gig sd card.
DVD recorder isn't recording onto a blank disk in DVD format.
You just may have an issue with your DVD recorder. Happens.
1helpful
Sound but no pictures
It seems problem of defective ccd imager IC, please confirm is this DCR-HC18E model Sony camcorder to guide you further.
Hitachi dzmv3000e digatal camcorder when disc is format and on record the disc only records the sound but no picture
I have exactly the same problem. If I tap the outside of the camcorder the picture comes back but it isn't a great picture and often slips back to the blank screen. I assume it's a fault with the lens. Sounds expensive too!
Jun 25, 2008 • Cameras
3helpful
2answers
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
2helpful
Will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
No picture
if the index go --:--:-- or 00:00:00 when you press play to view recorded material then you have a SERIOUS problem. That means heavy repair and cost. Buy something new.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
