Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
SOURCE: Lg washing machine WT - R852... LE error..bad
For LG washers 'LE' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
SOURCE: LG washing machine LE fault
not much... possible loose wire from stator assembly to main control also bad main control or sensor mounted underneath rotor /stator
