1 year late
my guess is fans work,, spin and blow, (unstated)
DVD eject button forks. unsatted.
the hot key for VGA was not pressed FN +?
and if did this correctly the vga works but the local CCFL lamps are dead, as all are this old now.
the manual on you PC covers the VGA port hot keys
on my HPs its Fn+F4 (together )
1: local CCFL cheap junk screen. lcd."back lamps dead"
2: vga
3: both
4: auto (on only some models)
CCFL dead and that huge battery shorted,killing the PC dead
are the 2 top failures on all 2010 and older PCs.
This sounds like Vid Chip failure, That has a very inexpensive mother board that can be replaced There is one listed on a popular site that sells used parts for $10.00 right now
most of these PC the CCFL lamps are dead
now.
what does seems to work man,fans blow?
cd tray button ejects ?????
if vga port is dead, using the correct key]
the 2008 PC the GPU chip can be bad.
many are(vast)
the 1st step is remove that relic large battery and run on AC power pack only
the fans turn, 1 or 2 possible
spin and blow, if not there is power problem
or the PC was never cleaned in 10 years
is the BIOS dead
does the flashlight trick work. this I do first after that relic battery pulled.
if the flashlite shows data, bingo CCFL IS DEad
all in 5 minutes work and 1 simple tool a flashslight.
Does not work on external either, that was stated in the question, This is s very cheap model to replace the mother board. AS I stated in my first reply you can get one on E*ay for $10.00,
SOURCE: Memory Problems for a Gateway Mx3215 Laptop
There are two different memory modules for that series.You can determine which you need by the chipset for you machine.If you have a Via VN800 Chipset You need the 1024MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v. If you have the NVIDIA nForce 410 Chipset The you need the 1024MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v Hope this clears up your problem
SOURCE: gateway M6340U hard drive problem
It sound like memory problem. Change the memory and test if the problem is solved.
SOURCE: gateway mt6821 power jack
The gateway document describing how to take that laptop apart can be found here. However, I'll just warn you that this is not an easy task, and sometimes the force of ripping the ******** the board ruins the board connections in that area and it will not fix it to get a new jack. This is rare, but know that it could happen.
SOURCE: Gateway laptop screen is black?
This could have several causes, including malware installed on your system, but is frequently the result of some kind of hardware driver conflict. Have you recently installed any new hardware or software to your system? If so, disconnect it and try again.
The black screen is an indication that the windows os is not booting onto the system. If you have the recovery console installed, or have the cds, you can run the recovery console to troubleshoot or repair your installation of windows. This procedure is different for xp or vista, so we need to know what os you're on, as well as any error messages you see when it fails to boot.
To begin with, try tapping F8 as it boots up and see it you can get into the OS options screen, then choose Last Known good configuration to boot windows.
Here's a great article to help you troubleshoot the situation, then let us know how it goes and what comes up..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Gateway Computer with Black Screen
hit the function key hold it down and hit the keyboard key with the monitor "icon" on it. It's usually F5 key.
Hope this helps.
