Question about Pramac GBW30P Encl Diesel Genset w/Perkins Eng
Genset does not start , alarm can't reset - Pramac GBW30P Encl Diesel Genset w/Perkins Eng
Posted by havealetapa on
Scott Alcott
    New Friend:
  • 22 Answers
What safety caused the alarm. if you cant restart it, it may be cause the problem that originally shut the engine down has not been fixed, it could be water level, low oil, high water temp, low fuel,over voltage, all of the above are probably run through the safeties. over volt, and water temp would probably clear its self after it sat a while. try turning off power to panel. for a couple minutes and see if it will reset, if not check water level. and oil levels
Posted on Aug 14, 2011
Starlight Power
    Sergeant:
  • 117 Answers
Diesel Generator Start-up Failure or difficult to start should check the following causes. 1. Failure phenomenon a. No explosion sound in the cylinder, white smoke from the exhaust pipe;
b. Black smoke from the exhaust pipe.
Practice has proved that in order to maintain the smooth start of diesel generators , four necessary conditions must be met: a. It must have a certain speed; b. The oil and gas circuits must be unobstructed; C. The cylinders are well compressed; d. The fuel supply timing. From the above prerequisites for starting a diesel generator, it can be inferred that the diesel generator cannot start or is not easy to start.
2. Failure cause
Diesel engine speed is low; a. Starting speed is too low; b. Improper adjustment after pressure reducing device is not put into the correct position; c. Improper adjustment of valve clearance.
The oil and gas paths are not smooth; a. There is no diesel oil in the fuel tank, the oil pipeline is blocked, the fuel filter element is blocked, and oil switch is not open; b. When the diesel engine is started, the ambient temperature is too low; c. There is water or air in the oil path; d. The fuel injection nozzle is poorly sprayed or does not spray fuel; e. The air filter element is blocked or dirty.
Cylinder compression is not good; a. The clearance between the piston and cylinder wall is too large; b. The piston ring is broken or the elastic force is too small; c. The intake and exhaust valves are not closed tightly.
The fuel supply is not correct; a. The injection time is too early (it is easy to kill the injection pump) or too late; b. The valve distribution is not on time.
This article will be helpful for this issue. https://www.dieselgeneratortech.com/diesel-generators/diesel-generator-start-up-failure-causes.html
Posted on Dec 06, 2019
sherlywang
    Master:
  • 425 Answers
The diesel generator set cannot be started first to find out the cause and then to troubleshoot according to the cause. There are many reasons why the diesel generator set cannot be started in the actual situation. The following items are for reference only.
1. No fuel or insufficient fuel;
2. The engine cylinder cooling water temperature is low;
3. The battery voltage is low;
4. The injection oil pump has air;
5, start the motor failure;
6. The control loop is faulty.
Posted on Dec 18, 2018
How do i do when some genset can't run togheter when we start the plant
im not sure are you asking about Phasing ? on a three phase gen set , yes extreme care needs be taken if you need to start one genset before shutting one off , in this case a Phase/sync meter will need to be used to keep from surging all the loads connected to genset , also all three phases of each genset needs to be "In sync" to be able to use a transfer from one genset to another , in sync refers to peek waveform on each genset, needs to be in perfect time or an "ARC" will occur , that could be detrimental to the connected loads if there sensative to this type
Jan 18, 2015 | Electrical Supplies
I can't shut my alarm off my bike won't start 2007 fxstc
Your alarm being on is probably also an anti thieft device. Disable or reset the alarm, your bile will probably start. You need to learn more about your motorcycle my friend.
Jan 25, 2013 | 2007 Harley Davidson FXSTC Softail Custom
Mazda mx5 will not start after flat battery battery now charged but soon as turn the ignition on the alarm goes off and will not start
You need to reset the alarm. If it's a Stock/original alarm, read the Owner's Manual or call a Mazda dealer. If it's not stock, you'll need to ID the alarm and look online for the instructions.
If your keyless remote fob has a Mazda label on it and is the ONLY one you have it's probably stock; if it's not a labeled Mazda, look for another name to find the alarm type.
GL,
Td
Oct 10, 2012 | Mazda Cars & Trucks
I have a factory installed alarm on my 2003 jeep cherokee ,how do i disable alarm
Hello! The drivers side door lock/unlock switch is more than likely defective...Having said that, the alarm system on Jeeps are a constant problem...To disable the system requires removing the drivers door panel and cutting the Light Green/Orange wire at the switch...And installing a 465 Ohm resistor...Not something done without the necessary skills...
I would have the vehicle towed to a Jeep dealer and have them test the drivers door switch and disable the alarm....Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 02, 2012 | Jeep Grand Cherokee Cars & Trucks
2004 Hyundai Elantra won't start, emergency flashers keep blinking, can't shut off, lights dim, can't jump start, clicking from under dash from relays. What could it be?
The 'Keyless Entry & Burglar Alarm System" is activated. You must 'Disarm' the system using the Keyless Entry Remove (Key Fob) to "Reset" the system. The reason the engine won't start is due to the burglar alarm - it has a "Starter Kill" circuit which is activated when the alarm is activated. The alarm must be DEactivated to DEactivate the 'Starter Kill' circuit.
Another way to start the engine is to get in the car, put the key in the ignition and turn it to 'ON" and wait 3 to 5 minutes until the emergency flashers stop/turn off. Afterward, you should be able to start the engine. NOTE: This does NOT reset the burglar alarm. It will go off again when you enter the vehicle without using the remote/key fob.
Sep 06, 2011 | Hyundai Elantra Cars & Trucks
The generator doesn't turn off after transfering power back to the utility
The transfer switch is responsible for starting / stopping the generator. Check your auto - start circuit. It is 2 wires that go between the genset and ATS. They are generally normally open. When the genset is to shut down this circuit needs to change state.
Jul 09, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
POWER GENERATOR EM650Z CANT START AFTER I PLUG A 1200W HEATER ON IT,WHAT CAN I DO?
You cannot start a genset with load. Think of it like a car with a clutch, You can't drive the car until you start it. You start it out of gear or while holding in the clutch. So try unplugging it or opening a circuit breaker on the genset until it starts.
Jul 09, 2011 | Electrical Supplies
It keeps peeping on every hour...don't have the manual. It is a watch from Target: Polyurethane Strap Digital Silver Oval Case Watch - Purple. Would like like to turn off the hourly alarm.
I know you posted this a while ago but I had the same issue and I just figured out how to solve it. You hold down on the 'Reset' button so it shows the alarm time and then while continuing to hold the 'Reset' button you press the 'Start' button right above it. Each time you press the 'Start' button, you turn the alarm and the chime every hour on and off. You know if its 'on' based on the little images on the top of the screen. The top left corner is the alarm and the bottom right is the chime.
Jan 03, 2011 | Watches
I have an onan 2800 gen that will not charge
If the govenor didn't work that means that you placed the linkage on the carberator the wrong way. This will cause the genset to overspeed and possibly stop the genset from creating voltage. If the genset does not create voltage then you won't have a charger. Fix the linkage first by looking to make sure that the throttle plate is closed before starting genset. Once you start the genset check for voltage.
Apr 12, 2009 | Watts Onan Portable Generator - 4000 ,...
Pramac GBW30P Encl Diesel Genset w/Perkins Eng Logo
329 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Robert Wooley
Robert Wooley
Ngoro
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
