Question about Amana ARS9266BS Side by Side Refrigerator
We have water leaking slowly from beneath the water/ice dispenser unit in our Amana side by side. It is 2 1/2 years old and this is a new problem.
Posted by cwhaskell50 on
Gene Meier
  • 2,341 Answers
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Posted on Aug 12, 2011
Amana side by side not cooling
What is the complete model number of your unit?
Dec 04, 2012 | Amana Refrigerators
The ice and water dispenser on my Amana Refrigerator slowly leaks water. Are there repair parts to correct this? And how is the plastic frame containing the dispenser removed from the door?
The problem is most likely not in the door. When the dispense button is pressed it actuates an electric solenoid valve in the rear of the refrigerator that opens and allows the water to flow. Over time the valve seals get worn and the water seeps by. This is what usually causes a drip at the water dispenser. If there is a drip at the ice side then the door is jammed and is not closing fully. This allows the ice at the opening to melt and drip. Hope this helps. Please accept and rate. Good luck.
Dec 08, 2009 | Amana ARSE664BS Side by Side Refrigerator
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Ice dispenser not working
Ice auger in freezer compartment not working. Common problem with GE side by sides I know of at least 3
Jan 21, 2008 | Amana ACD2232HR Side by Side Refrigerator
Leaking icemaker
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
Oct 29, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Amana ARS9266BS Side by Side Refrigerator Logo
210 people viewed this question
Top Amana Refrigerators Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
