Gateway FPD2275W LCD Monitor Logo
Joel OConnor Posted on Aug 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought a used LP2207 (that had been tested by the store) and it worked the first evening, but the next morning the screen flickered white with some colored streaks and then stayed all white. None of the buttons changed that; did I hit the wrong one? Can not find manual online.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Aug 13, 2011
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366046
Points
33650
That is the sign of failed T-CON board or bad DC feeding it from the logic board.
More likely to need new LCD panel, I hope you can take it back.
See my pictures to see if that is what you are seeing on your screen:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Testimonial: "Thanks, that seems like it. Taking it back."
Samsung TV UE65mu6120k fault
Any information as to the fault?
My macbook dropped ..now battery cord doesn't light up very much and flickers... alot..? Is this an easy fix? Or is this gonna cost some bucks..? What could dropping the macbook have done to it
macbooks are very expensive to fix if you take them to the so called genie bar. so try a mall store to fix it or if money i no problem take it to the apple store.
2answers
Hi i have a 2002 lincoln continental with 31000 miles car doesn't start if i use a jump starter car starts and keep running for the time you deserve i test the battery and looks fine i test alternator and...
I have a 01 Lincoln Continental that wouldnt start. After paying $69 to the repair shop they told me that the alternator and belt are working like they should but the battery wont hold a charge. I took the battery to Sears (6 month old Diehard) and after a day and a half they said the battery is good. Now the car starts each time but the lights(inside and out) all flicker and when you press the gas they flicker more? After about 5 minutes the flickering stops. What could be the problem?
White as pink, black as green
boot up your laptop and take a magnet in your hand and revolve around the screen the screen might go crazy but all the colors will be back in a while. :)
Wont cut on
I left it alone overnight and when i went to charge it da next morning, it waz workin fine.
Olevia 26" Flat Screen
I too had a similar problem with my 26" Olevia LCD TV, except it would flicker at different frequencies like a strobe light.  The flicker would even increase in speed, giving the visual illusion that the TV was about to blow up.  After several power-on, power-off, unplug, repeat, I was about to give up and think about looking for another TV. I saw your posts here and both of you "hit" the TV and it seemed to fix it, right?  Same here -- I gave the TV several good lateral "whacks" upon the outer edges of the unit!  The whacks weren't violent, just slightly "jarring" and after that, the TV stopped the flickering.  As you've said, it is quite juvenile to go beating on electronics, but interestingly enough, this method of "fixing" the electronics does at least seem to have an effect if done correctly.
I do also note that I went into the TV's menus and intentionally set the "Back Light" setting to "Dark" and "DNR" to "Low" to perhaps attempt to lesser drive the back light.  Since the beatings and then the much more rational idea of changing the menu options, the TV has worked, at least for a while now, relatively well.
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
