After coby dvd player model 217 plugging in the wall socket, power/standby inicator light comes on, but after pushing power/standby button red idicator light never turns on. And pushing play/pause button, disc does not red because disc never rotating.What could be problem?
Did you try pushing the On button of the set? New batteries for the remote? Power Reset, unplug from the wall socket, press and hold the power button for one minute, plug it back in?
Hello just unplug the DVD player from AC wall power socket, and lst it be in that state for at least 10 minutes and the replug and see whether it helps you. If not, the power supply inverter board of your DVD player is faulty. some fault are repairable, and some others are not. Anyway, it will be best to replace this board as card basis, rather than get it repair. OK.
Hello, here is a sample for auxilary connection for the chdvd300:
. Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
The switch is for 'REC' 'Standby' and "PLAY".
If you leave it switched to "Play" and pull the plug and push it in to the wall receptacle (mains) it should start playing after a few seconds delay. The same for "REC". You use a timer unit on the power cord for those.
If you have the switch in the middle position and plugged-in, you should have a tiny Red LED illuminated. Push "Power" and it should start-up and be ready to use in a matter of a few seconds.
Check P611 in power supply. Its a 1.5a 60v pico fuse (yellowish in color). Also disconnect plugs when in order not to get false reading when checking other components
do you see the laser light come on when the disk spins if not it has probably lost power or failed, if so sometimes the laser head gets moved to close to the drive mechanism and the motor cant pull it out. i have found several of these that had this problem.
if it does nothing when you push the standby button to make it play the most common problem is the power standby sw is bad. do you know how to use a miltimeter if so test the voltage through the swithc when you press the button.
