My remote is locked and not working, AC is working fine. and on the display of remote a key symbole is blinking when I press any button, so how do I sole my problem, my number is 9958488770 and email [email protected]
The yellow car and lock symbol that appears on the dashboard of your Pontiac G6 indicates that the vehicle's security system has detected a problem. This symbol may appear if there is a malfunction with the system or if the system has been triggered by an event such as a collision or attempted break-in.
If the security system is functioning properly and the yellow car and lock symbol is still displayed, it is possible that there is a problem with the security system sensor or wiring. It is recommended to take the vehicle to a mechanic or a Pontiac dealership for further diagnosis and repair.
In the meantime, you can try pressing the unlock button on the remote or using the key to unlock the doors and see if the symbol disappears. If the symbol remains displayed, it is possible that the security system will need to be reset by a professional.
When not in a setting mode, pressing and holding UP & DOWN keys for 3 seconds, the key pad is locked. After setting it, the LOCK icon will be displayed on LCD to indicate that key pad has been locked and all the keys are disabled. At that case, the remote won't send out any codes. The LOCK icon on the LCD flash 3 times, 0.5 seconds for ON, 0.5 seconds for OFF, and press & hold UP & DOWN keys for 3 seconds, the remote is un-locked.
this problem arises when u disturbe the remote settings. to make it operate again use the following procedure
1.on the power from stablizer
2.press the button in remote with 'key' sign once
3.now adjust the number displayed in remote 9 99 to 3 25 by using 'down '(temp adjustment button) key.
4.press again the button with 'key' sign
5.now ur ac is reinstate
enjoy the breeeeeeeeezzzzzzzzzzzzzzzzeeeeeeeeeeeeee
thanks
There is a button marked "C.LOCK" (short for child lock) on the remote (near the bottom of the remote). Press that button to unlock the player. If it works, the orange key-symbol in the display should disappear.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
When you reintilize the scanner, it should lose all programming and settings. Hold down the Tune/Clear button while pushing the reset button. Do not release the Tune/Clear button until the display clears and returns.
Look at the keyboard and find the button the shows the symbol for a key and a symbol for a light bulb. Press the FUNC button and then the key indicated above. The words key unlocked should appear in the display. Repeat the process to lock the keys again.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's...
1) Turn the program selector to any program as you would doing laundry. Add your items...
2) When you close the door the "start/pause" light flashes...
3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved.
4) Press the "select" button until the desired volume or "off" is reached/displayed.
5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed.
As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
This is the procedure for a reprogram of the remote's from the factory service manual, if it doesn't work then u may have a receiver issue. Use this Procedure for Vehicles with Driver Information Center Buttons
This information is in your Owners Manual in the Drivers Information Center Section.
1. Insert Key and turn to ON position so you can access Driver Information Center
2. Press the vehicle information button until PRESS TO RELEARN REMOTE KEY displays 3. Press the set/reset button until REMOTE KEY LEARNING ACTIVEdisplays 4. Press and hold the lock and unlock buttons on the first keyless remote at the same time for approximatley 15 seconds. A chime will sound indicating that the remote is programmed.
5.To program additional remotes at this time repeat step 3. This vehicle can have a maximum of eight remotes programmed. 6.To exit programming mode turn key off and remove key. Test remote(s).
Use this Procedure for Vehicles without Drivers Information Center Buttons
To access this display, the vehicle must be in Park (P) with key in the on position (as far as you can go without cranking engine)
1. Press the trip odometer reset stem until RELEARN REMOTE KEY displays. 2. Press and hold the trip odometer reset stem for three seconds. The messageREMOTE KEY LEARNING ACTIVEwill display 3.Press and hold the lock and unlock buttons on the first keyless remote at the same time for approximately 15 seconds. A chime will sound indicating that the remote is programmed. 4.To program additional remotes at this time repeat step 3. This vehicle can have a maximum of eight remotes programmed. 5.To exit programming mode turn key off and remove key. Test remote(s).
