Let's work with FM as that is ONboard and can't be connected wrong. Does THAT work?
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
I was looking for informations about the Sherwood AI-2110R and it seems to be an integrated stereo amplifier with good power. However the "external" plugs seem to deliver only the "passing" sound, what means that the signal needs to be powerd by an external amplifier. I don´t believe that a simple surround set would be able to do that. Maybe the best solution would be to hook another amplifier to the external plugs, via an "aux" connection.
Something doesn't sound right. The standby circuit is usually very simple. The "regulator" is just a transistor. Can you request and post the parts that he/she can't find. I should be able to get you a source or substitutes.
