I was given a 6200AT laptop computer. When I boot up, it requires a password to proceed to Windows. I don't know the PW. Someone said removing the lithium battery and reinstalling would allow access w/o a PW, but I don't know where the lithium battery is. Can you tell me or is there another way to bypass or update the PW?
Posted by flyingsausse on
Mosaub Al Masri
    New Friend:
  • 66 Answers
You need to get back to the store they will give you the password als u can try default pass ADMINISTRATOR
Posted on Aug 12, 2011
A temporary password.. Please answer on "[email protected]" as I don't use facebook.
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jan 17, 2013 | HP Computers & Internet
Don't know HDD #1/SSD #1USER PASSWORD ON MY TOSHIBA
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Oct 03, 2012 | Toshiba Satellite L455S5980 Notebook
How can i reset my windows 7 password?
If you can handle Hirons, this one's a breeze. Licence key purchase is required though. Nor does it specify EFI / GUID. Maybe contact them before purchase.
Oct 03, 2012 | Computers & Internet
How to reset administor password on Dell mini laptop
Forgot windows password? Don't worry about it, when I forgot the password, i remove the password by the following steps,
Step1: Download and install Windows Password Recovery Tool Professional.Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn aWindows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4: Remove the forgotten Windows password with the burned CD/DVD/USB. Then log on to Windows without a password.
As the above method, you can finishwindows password remover, I think it is helpfull for you.
http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Aug 18, 2012 | Dell Inspiron Mini 10v Netbook Computer
Don't remember the admin password & has several things pw protected as well..
I forgot windows 7 laptop password, i just reset windows 7 password by the following steps,
Step1: Download Smartkey Windows Password Recovery Professional from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows 7 password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to remove Windows 7 password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
Hope it can help you well.
May 27, 2012 | Computers & Internet
How do i undo my system password?
System Password? No Such Thing!!!
The Three Types of Passwords are:
Bios Password - which is a password the comes up before the machine will even start booting. If you set this password, you should know it. The only way to remove a Bios Password if the take the laptop apart and remove the CMOS battery that is on the motherboard and let it sit for an hour or so until the computer completely loses memory of everything including the date, time, passwords.
Hard Drive Password - The hard drive password is set by the owner of the laptop to prevent thieves from getting to sensitive data if the laptop is stolen. 99% of the time if someone don't know the Hard Drive Password, then the laptop is stolen. If you're smart enough to set the hard drive password, then you should be smart enough to remember it. The real owner can sometimes set the password remotely once the laptop is stolen. The only way to remove the hard drive password is type in the correct password.
Windows Password - This password is associated with a user id that shows up once windows has completely booted up. If you forgot this password, it can be reset depending on the operating system.
Windows 7 requires a Password Reset Disc that everyone should take the time to create if they want to use a password on their user account. Without the disc that was created on that computer you won't be able to get in.
Windows XP and Vista - Turn off the computer, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select Safe Mode and let the computer boot. When it comes to the login screen it will show the Administrator account and the user account for which you forgot the password. Click on the Administrator account and just click ok or enter for the password (hopefully you didn't create an Administrator's password and forgot it too). When you see the windows desktop in safe mode it will look differently. The icons will be bigger and the screen darker, but that is normal in safe mode. Click Start/Control Panel/User Accounts and select the user account for which you forgot the password, then select REMOVE PASSWORD, click OK and reboot your machine. This time let the computer boot up as it normally would.
Mar 25, 2012 | Toshiba Computers & Internet
Right. i have a toshiba nb305-106. i forgot my password and want to restore to factory settings. i don't have a removeable passwrod back up on a flash drive and holding the 0 (zero) key doesn't...
There is a software called opencrack download it and burn to cd then boot from it you have to follow the instruction then you can reset the password or if you have original Toshiba restoration cd use that but it format all your files.
Sep 06, 2011 | Computers & Internet
My daughter lost her password for her netbook how do I rest it
Hello first of all what operating system is she using if windows xp then boot the machine in safe mode, chances are it came out the factory with no password on the hidden admin, after you boot into safe mode you will notice a new account you haven't not seen before call administrator. choose the admin and once in the account simply go to user accounts and remove her password. if you are running vista or windows 7 then this will not work for you the next option would require software I recommend hirens boot cd 10.6 here is the link bootcd download and extract the file, you need a archive program like winzip or winrar. the zip file wil contain an iso image of the disk that you will need to mount and burn to a disk would use damon tools which is also free. once you have created your boot disk you can now boot your daughters computer from the boot cd, once booted into hirens several tools with appear simply navigate to password tools and follow the step by step wizard that will remove the password in seconds.
hpe this helps please feel free to reply for more detailed support.
May 29, 2011 | Acer Aspire One Netbook 8.9" Notebook
My daughter forgot her password for her netbook how can i reset it?
i think you can do it from "safe mode" anyway shut the computer down, turn it back on and hit F8 choose safe mode. wait till the logon screen appears..there should be no username/password.
Right click "MyComputer" scroll to manage, Expand "Local Users/Groups", Open "Users", Right click your daughters account name, Reset Password/Set Password
hopefully that helps...if not then you may need to use a crack cd to get in...google "Winternals" or "Spotmau"
-mk3ride
Dec 31, 2010 | Sylvania G-Netbook
Windows PW Problem
I've solved this by going in as Admin, and removing the .Net user account that MS sets up with install of .Net. If you can't get into the machine at all, look for a copy of Hiren , it's a bootable CD that can remove XP passwords and much more, just be careful with it!!
Good Luck!
Dec 03, 2007 | Xybernaut Atigo T/HB Network Terminal
Computers & Internet Logo
56 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
