Question about Emerson CKS1702 Clock Radio
The alarm is on but doesnt sound when is time
Posted by bubit42 on
Mosaub Al Masri
    New Friend:
  • 66 Answers
There is maybe the inside speaker broken try to replace it
Posted on Aug 12, 2011
I have a phs8905 sharp watch and I can't figure out what AL is I think it's alarm but it doesnt effect anything. The bell symbol turns the alarm on and off but I can turn both the AL symbol and the bell...
A is for ALARM, when you want an alarm to sound just set the time you want to be woken or reminded of something then turn alarm on, an alarm will then sound at the time you set
Mar 02, 2018 | Watches
Why doesnt my audible alam sound when the alarm is trigged.
For starters first check the wire going to the horn, it may be cut.
Jul 10, 2014 | 2002 BMW 3 Series
How to re activate my alarm system on corolla 2010 factory alarm
change the set up in anti thief control module . use by toyota scaner
Dec 21, 2013 | Toyota Corolla Cars & Trucks
Had original radio replaced-no problems until I
lock your door and hold the key in that position, and then turn it the other way and hold it until they roll up, this should set the alarm back. If that doesnt work try replacing the radio with the stock one, your third option is to bypass the alarm module.
Oct 18, 2013 | 1996 Volkswagen Jetta
Montres carlo 3042f doesnt play sound
sounds like you have turned function off you need to go into your menu for alarm and alter setting..if you not got the instructions you can get them of the world wide web.
Mar 26, 2010 | Bulova Watch
When i lock the doors on a 2002 ford explorer about thirty minutes or so the alarm sounds. even if not activated. the only way it doesnt is when i leave it unlocked. any suggestions?
Check to see if when the alarm goes off if the interior lights are lit. Ford's have a problem at times with the door pinswitch in the door latch leaving the interior lights on, or coming on unexpectedly. Is this a factory installed alarm? WD40 sprayed into the latch will sometimes fix this problem.
Jun 12, 2009 | Code-Alarm Code Alarm Transponder
Alarm doesnt beep
Turn the ignition on and off 5 times without starting the engine and the alarm will chirp and will be out of "Valet mode"
Mar 24, 2009 | Vehicle Parts & Accessories
Alarm sounds low
change ur alarm music else keep ur alarm music as some high tone song and try
Jul 31, 2008 | Nokia 6233 Cellular Phone
Nokia 6233 alarm not working
You might have your phone on Silent Profile or the time set wrongly. Make sure you have selected a Sound for the alarm.
Feb 17, 2008 | Nokia 6233 Cellular Phone
Alarm is no longer working
sounds like sofware problem. try a factry reset. type 2945#*# on your main screen then just go to the bottom and the option is there. you will lose everything on your phone. if you really need the alarm that would be your best option as the options for the kg800 are very limited since its a closed source
Aug 29, 2007 | LG KG800 Cellular Phone
Emerson CKS1702 Clock Radio Logo
132 people viewed this question
Top Emerson Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
