While moving unit was laying on it's back found small amout of ? transmission fluid? perhaps 1/8 pint also found a cotter pin 1-1/2 brass Please respond ASAP I am on a borrowed computer and need help fast. Thanks. Be sure to notify me at this computer ONLY UNTIL 4 PM TODAY
THEN USE [email protected] THANKS
SOURCE: Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
SOURCE: Trans will not disengage
either you have something stuck betwwen the two tubs(ie. a sock. ) preventing the tub from free spinning.or there is a clutch mounted on top of the transmission not engaging, as far the agitator not spinning correctly sounds liek the agitaor dawgs are stripped preventing proper agitaing(bottom of agitator works fine but upper portion free spins both ways without resistance?? correct??
SOURCE: The tub is very loose and moves all about, even
Not a solution but if the machine is "Oldish" or has had heavy use, it sounds like the tub bearings are worn.
This may have even worn the bearings while the cotter pins were out.
Very expensive to repair.
Get quotes and then you may consider the cost of repair against buying a new machine.
Sorry I couldn't be of much help.
SOURCE: Whirlpool washer WFW8300SW03 bellows replacement
The following link explains, step-by step, how to replace the door bellow on a Whirlpool Duet:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you have questions about this repair, or require additional assistance, please let me know. I hope this helps you.
SOURCE: F 02 Error code, took apart and found 2 small
WHAT DID YOU TAKE APART AND FIND THE NAILS? WAS IT THE PUMP? SOME MORE NAILS MIGHT HAVE GOTTEN BACK IN THE PUMP OR THE PUMP IS DAMAGED.
