Question about Lexmark F4270 Plain Paper Inkjet Fax
I have a Lexmark F 4270 printer scanner fax unit.It fax and print but does not want to scan.If I put the paper in it gives the following error code:Acro Rd 32.exe Can u help please..
Posted by khfourie on
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: Lexmark 4270 driver for win98 or ME needed...Please
You cant download from lexmark.com well try searching for drivers on a search engine like google perhaps. I just found this one and this seems to work. Use this link and download the file. http://download.opendrivers.com/showfile.php?file=/printers/lexmark/CJG4200EN.exe
Posted on Sep 22, 2007
checkitright
CheckitRight
  • 1363 Answers
SOURCE: Lexmark F4270 Paper Jam Problem
Go to the menu and make sure it is set to Letter and not Legal size.
Posted on Oct 29, 2007
Anonymous
SOURCE: need help on my lexmark x 4270
If you are with a lexmark printer switch to windows xp or just try to buy another printer... If you are using this x4270 printer probably it is famous for faxing problems so probably you must not try to fax...Try lexexpress if you are in warranty
Posted on Jan 13, 2008
Anonymous
  • 3 Answers
SOURCE: Lexmark 4200 Series printer/fax
Tried what blkghost suggested above but had to tweak his advice slightly.
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
YAY problem fixed.
Posted on Mar 20, 2008
Anonymous
  • 706 Answers
SOURCE: purchased an X4550 Lexmark printer/scanner,
Here is a link to the user manual , note pages 90 - 92 etc discuss clearing a paper jam..
http://images.lexmark.com/publications/pdfs/2007/3500/v2103618_en.pdf
Hope this helps you..
Regards
Posted on Sep 19, 2008
I have a lexmark 4270 printer but i can't send any fax or scan because paper jam.what i do?
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark X4270 All-In-One InkJet Printer
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 15, 2010 | Lexmark X2550 All-In-One Printer
Remote fax error when sending a fax
Does it only happen going to one certain fax destination or every destination? There are some things to try on the Lexmark web site.
Go to www.lexmark.com and click Support->Technical Support. Type in 4270 in the 'Search by Model' box. Type in 'Remote fax error' in the 'Search the Knowledgebase' box. There is a topic called 'Problems Sending a Fax to Specific Fax Machines' that has some good general tips.
Steve
Feb 26, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4270 won't feed paper to print or copy!
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Good Luck
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4270
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark X4270) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4270
the lexmark f4270 displays an error message #1203. how do i get the printer working again
Feb 28, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Need help on my lexmark x 4270
Fax does not require installation on the PC. Driver for Vista is here: http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:438:0:0
Aug 29, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark F4270 Plain Paper Inkjet Fax Logo
Top Lexmark Office Equipment & Supplies Experts
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
