Question about Westinghouse Refrigerators
We have replaced the seal on the freezer part of our Westinghouse Mastermind Fridge/Freezer Model BJ505S-R. The door doesn't seem to seal properly. Is there a way to realign the door to make it a tighter fit?
Posted by normandenise on
Darren Jones
  • 41 Answers
I don't know why when people respond they just don't tell you the answer, it's always something opposite and always something to promote their own posts.
Ok here is the correct answer , the door is not sealing beacuse of the common fault of the centre hinge bending, either try loosening this hinge screws and realign it or change with a new one. Cheers
Posted on Jan 27, 2012
  • Westinghouse Master
  • 17,130 Answers
Please check on the video and get some tips to redo the work done on changing the door seal.
Sometimes this must be redone to keep the alignment in order for a correct fitting.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/1145/how-to-replace-a-freezer-door-seal.html
Posted on Aug 12, 2011
Candy CPCA240FFK top fridge door seal required?
They need to be for the model itself as opposed to by size
Candy CPCA240FFK Seals - Fridges & Freezers - eSpareshttps://www.espares.co.uk > ... > Candy > Seals
Fridge/Freezer Door Seal. 3.6. Genuine spare part for select models of Candy, Hoover and Kelvinator fridge and freezers More information. In Stock.
Candy Door Seal for CPCA240FFK - ES929589 - eSpareshttps://www.espares.co.uk > product > door-seal
Will this part fit my Appliance? Yes. This part is compatible with Candy CPCA240FFK Fridges & Freezers. Not what you're looking for?
Candy CPCA240FFK Fridge & Freezer Door Seals - Ransom Spareshttps://www.ransomspares.co.uk > ... > CPCA240FFK
Buy Candy CPCA240FFK Fridge & Freezer Door Seals from the authorised stockist. Low prices with our Price Match Promise & next day delivery - Ransom Spares.
Candy CPCA240FFK Fridge & Freezer Spares & Partshttps://www.ransomspares.co.uk > ... > Candy
Buy genuine replacement Candy Fridge & Freezer CPCA240FFK spares from an authorised supplier. Price match promise and next day delivery.
M y Westinghouse mastermind fridge/freezer just runs and runs , it is cold but hardly ever cuts out
Hay Paul ,
1) Are the door gaskets torn ?
2) Is the fridge empty , in order for the unit to cycle it must replace warm air with cold air .
GOOD LUCK
APPLIANCES R'EN
2answers
2answers
Model # bx2255w Amana Refridgerator bottom freezer works but refridge isn't cooling any more. Is it time to retire our approx 15 year old fridge or is there an easy fix?
If you have high humidity or the door gets opened a lot, the evaporator coil may need a good defrosting. There are defrosting devices in the unit like the timer, heating coils, thermostats that could be bad. There should also be a small fan in the freezer that transfers the air to the refrigerator section. If that's not spinning only the freezer will work.
If you find the fan and it's working you can do a thorough manual defrost by removing the food, unplugging the unit and letting it set for a day with the doors wide open. Have some big towels handy :)
After a day, plug it in and see what it does (don't add food, yet). If it cools down then you will know that the compressor is still good and it's worthwhile to fix.
Easy fixes: Timer and fan.
Moderate fix (cheap part - more labor) - Defrost thermosat
Pain in the **** fix: Defrost heaters.
Ed
I am wanting to replace the freezer door seal on a upright fridge freezer model BJ 423TR*16
contact this company here http://www.allbrandonline.com/ you will be able to order your door seals from this company and they will mail them to you 1800-252-7500 is there number also remember after you install the seals to coat the seals with petroleum jelly or vaseline and leave the door of the freezer closed for at least 3 hours this causes the door seal to mold properly and keep the proper suction to make sure the door stays snug and grabs onto the frame if you have any questions message me back and please remember to rank how this opinion has helped it allows me to continue helping people in similar situations in the future on this site Thanks again Rick
1helpful
I have a westinghouse 2 door fridge that is not getting cold enough, 7 degrees in the fridge, freezer seems ok. not sure where to set the controls as i have no manual. its a 2 door,freeze at the top and...
i think your ref working normal try to adjust thermostat setting on the fridge if you want to cool lower than 7 degrees but this temp. allready can chill the food. then you said that freezer ok.
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Dan Webster
Dan Webster
Ekse
Dale Copeland
Dale Copeland
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
