Question about Dictaphone 2740 Desktop Cassette Transcriber / Recorder
Best dictaphone for conference Recording - Dictaphone 2740 Desktop Cassette Transcriber / Recorder
Posted by praveenan556 on
Javier Gonzalez
  • 207 Answers
Hello the Dictaphone 2740 does not have the option for telephone record or conference recording you need the Model that is really similar to the 2740 the model is 2750 this model has telephone record option and conference record capable.
Note: for telephone record you need to buy a separate adaptor like this ECS-DPRC
Posted on Oct 30, 2011
Dictaphone intermittently shuts off while recording.
The power jack sometimes comes loose on this model. With the power on, wiggle the jack. If it powers off, then it needs to be resoldered. Service can be done by dictationmall if needed.
Oct 10, 2011 | Dictaphone 3740 Desktop Cassette...
I need a handsfree headset recording device for the dictaphone 3750
Hello this is a great solution
http://www.tvps.com/Products/Nuance-Dictaphone-0421-C-Phone-Hands-Free-Overhead-Headset-with-Boom-Microphone---New__ECS-CMH.aspx if your unit is already modified for hands free with the 3.5 extenal jack mic input if not you also can send your unit to modified Send an email to [email protected] or call (805) 644-9525
Jun 08, 2011 | Dictaphone 3750 Desktop Cassette...
Any function I press on the foot pedal results in a request from the unit to "press conference". What do I do to make this work?
Hello you have your unit set up for Hands free recording Follow the next step
Press and Hold Search and Erase at the same time then you will be and the setup mode press play into you see hands free and press FF to say No then press Pay and press stop to exit.
Jun 23, 2010 | Dictaphone 3750 Desktop Cassette...
Dictaphone use for Medical Transcription
You'll need a digital recorder (Dictaphone makes one - a Walkabout Model 5220). Transferring a recording from an analog (tape) machine to a PC requires a patch cord to hook it up to your PC, then some sort of software to record it while it's playing back.
May 12, 2010 | Dictaphone 1243 Handheld Cassette Voice...
I need to record something with Dictaphone 3750 - I have no manual and there is just a Tel. Rec button. Help
If you press and hold the 'Conf' button, the machine will record using it's built-in mic (located on the right-hand side of the machine, closer to the front). It is probably recommended to get a microphone that plugs into the machine for better recording quality. Depending on what you're recording, you could get a handheld microphone or a telephone record adapter that plugs into your phone and the back of the 3750 (press and hold 'Tel Rec' to use that).
Aug 08, 2009 | Dictaphone 3740 Desktop Cassette...
Foot pedal won't work with hands free microphone
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
Hope this helps...
Apr 13, 2009 | Dictaphone 3750 Desktop Cassette...
Copy the recording
this phone has a 2 hour built i recording faeture & also has a audio outpout port but no usb port, so if u want to transfer to pc, u will have to connect the outport thru a stereo male EP to stereo male EP to ur laptop or pc & rec it with some software( audio grabber easily availabel on net) whilst playing the recording.
otherwise better options like CENIX digital recorders are avilable that can take care of the requirement that u mentioned!
Jun 11, 2008 | Panasonic KX-TS730S (KXTS730S) Audio...
VOX
On the right-hand side of the unit, there are two buttons with on/off positions. Both the Speaker and VOX options should be in the off position. When VOX is turned on, it only records when it monitors a level of noise. I do not have it turned on ever.
Jun 04, 2008 | Dictaphone 3750 Desktop Cassette...
Instructions for speaking into a hand held dictaphone
Make sure that 'VOX' or 'VA' isn't turned on. This is Voice Activated recording and is designed to record only when the person is talking. The problem is that sometimes it'll cut in or out when you don't want it to.
Also, if the handheld has a 'Dict/Conf' switch, put it into 'Dict'. The 'Conf' setting is for conference recording - which will make the mic more sensitive and pick up more background noise.
Feb 13, 2008 | Dictaphone 1243 Handheld Cassette Voice...
Dictaphone 2740 Desktop Cassette Transcriber / Recorder Logo
123 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
