If you sue external speakers or headphones, follow these instructions. If you have a notebook computer & are using the onboard speakers, skip to the *Windows section below.
You can start by checking your speakers, if any. Make sure they are powered on and functional. You may also want to test there speakers on a different computer just to make sure.
If the speakers work on a different computer but YOURS still does not have sound, try a known-working set of headphones. Make sure the jack is seated correctly as it may be loose.
*Windows:
Check the volume controls on in Windows. If windows does not have any volume controls, then chances are, the sound drivers are not installed. Check your computer manual to find out what model it is, then visit the manufacturer's website to download the appropriate drivers and software for the sound card.
Note that if you have used external speakers or headphones anytime before this issue started, you may have to re-plug the device & unplug it again & allow Windows to detect that it's unplugged (for HD-capable audio devices in Windows Vista or 7).
If you do have HD audio in Windows Vista or 7, right-click on the volume control in the notification tray on the bottom-right corner of your screen and select "Playback devices"...
... then make sure you choose the appropriate output device (whatever it is that you actually use: Speakers, headphones, HDTV output, etc).
