SOURCE: Eureka the boss vacuum cleaner brush won't turn
Take the top cover off, remove the torx screws on each side of the motor housing, remove the screw on the back holding the hose, then you just have to compare the 2 before putting on the new one. Can't tell for sure without a model number to get you a picture. What isn't on the new base, take off the old base and put it on the new one.
SOURCE: Reset button for Eureka 431 bagless upright???Where is it?!
If the red light is one the says "check brushroll" then you have to take it apart to find out what the problem is. It might be that the roll has too much stuff rapped around it so you have to take it out and clean. It could also be the rubber belt is not properly in place. Once you take the bottom off the belt should go on the far right side. Those are the only things i can think of. I have had mine for 3 years and have never seen a reset switch. Usually when my light comes on it is because there is a lot of hair rapped around my brush roll.
SOURCE: Eureka boss 5893A brush roll does not work
you have to prss the pedal and lean it back the brush roll wil enguage
SOURCE: Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
SOURCE: new Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
