Question about ECHO1USA Zmodo 8 Ch Dvr 3g Mobile Usb With 1000gb Drive H.264
My remote isn't working the mouse isn't responding no buttons are working on the dvr
Posted by sexiestlilma on
kevincrave
    New Friend:
Try pressing 0 on the remote. This locks and unlocks the screen for some reason
Posted on Jun 20, 2012
  • kevincrave
    kevincrave Jun 20, 2012
dixsolutions
    New Friend:
I am having the same problem.
Posted on Aug 26, 2011
Remote isn't working for my Kohler C3-200
Sounds like bad remote that only works partially or some parts on toilet vent bad.
Apr 09, 2013 | Kohler C3-200 Elongated Toilet Seat
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Samsung SMT-H3270 DVR not responding at all
The DVR unit still have power and display functions on the DVR small LED screen indicator on the DVR unit correct?And the DVR unit have not been in used for awhile and alway been plug in the power outlet for power like 24/7 hrs for power correct?Yes to all these questions,possible the DVR unit have software lockup or power glities some where before,possible the DVR unit have lockup and looping the software firmware of DVR unit not responding correctly for to the DVR unit to work or responding to any screen display functions.Tries unplugging the DVR unit for like about an hour and plugging power it back in for the DVR unit for the software to reboot itself.90 to 95% the unit will work again as u first got the DVR unit.
Oct 28, 2012 | Computers & Internet
When i reboot my Zmodo dvr I Can't get menu to come up or mouse to work HDD light keeps flashing,blinking hdd light,HDD indicator light
I had the same problem. Did their online tech support and Patty told me to hold down the "rewind" button on the DVR for 20 secs. You should now be able to right click your mouse to access the on screen menu. You will now want to go under system, and a/v setup and change the device to VGA instead of Vout. Now you can reboot and not have to go thru holding down the buttons anymore. Worked for me.
Oct 02, 2012 | ECHO1USA Zmodo 4 Ch Complete Dvr Kit -...
Can't get menu to come up or mouse to work. HDD light keeps flashing.
Try pressing '0' on the remote while pointing it directly at the IR sensor. There seems to be some undocumented feature with Zmodo systems that use this as a first guard against unauthorized access. Mine occasionally quits responding and I came across this in a forum post somewhere sometime back. The system should beep when you do this and toggle between one beep and two, one or the other unlocking the controls. Just try it after each beep sequence as I can't recall which is unlock.
Jan 18, 2012 | ECHO1USA Zmodo 4 Ch Complete Dvr Kit -...
My Lorex DVR turns off or resets every 2-5 minutes, the buttons on the DVR don't work and the DVR does not respond to to the mouse or remote, I have called both customer support and technical support...
Its the power supply. Look on eBay as there are several sellers with lorex ac adapters (power supply) just enter ac adapter and you're model # ex...sg19ld800. The 1st six letters and or numbers are important. You may also try Google for a seller, or amazon. Lorex have issues with this component. If dvr, turn the screen saver option under the display section of the set up screen on with the times you want it to automatically turn on/off. You get tons more life.
Nov 07, 2011 | Home Security
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
DirecTV receiver R15 won't respond to remote RC23
Well, I took the DVR apart and found the power board completely intact, no bulging capacitors. However, the Mother Board had a 220uf/50volt cap that was bulging, so I replaced it. By the way, 'DigiKey' is the only place to go for electronic parts. They'll hook you up! The DVR still wouldn't respond to the remote. Darn it!
So I took both of my DVR's apart and swapped out the Front Board (the one with the Photoamplifier in it) and the DVR would now respond to the remote. OK, so now what do I do. I still have one DVR with a bad Front Board. I started to look on ebay for an old used R15 500 that I could swap parts from...remember, I own my eqipment and the goal is to preserve what I have recorded on the Hard Drive. R15's were going for around $50 -$80. Then I got to thinking. I still had an old non-DVR Direct TV Receiver in my closet I never planned to use again. My thought was: even though it wasen't the exact model receiver, it did use the same remote, so the frquency that the Photoamplifier worked at should be compatible.
So I took apart this receiver unsoldered the Photoaplifier. I then removed the Photoamplifier from my malfunctioning DVR and installed the part from my unused Receiver and it fixed it. So long story short(too late for that) the Photoamplifier was faulty. I tried doing some cross checking and a company in China called Raytron makes the part. The failed part did not have a part # and Raytron has several different Photoamplifiers that operate at different frequencies. This made it impossible to find the right part without schematics or knowing what the freqency is. So at least we now know what caused the non responce to the remote.
Jan 31, 2010 | Directv RC23 Remote Control
Mouse not responding
Are the batteries good?
Try
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
May 24, 2008 | Kensington Comfort Type Wireless Optical...
ECHO1USA Zmodo 8 Ch Dvr 3g Mobile Usb With 1000gb Drive H.264 Logo
553 people viewed this question
Top ECHO1USA Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you an ECHO1USA Home Security Expert? Answer questions, earn points and help others
