Question about Danby DFF8802 Top Freezer Refrigerator
Freezer is cold enough but refrigerator doesn't get to temp. Any ideas?
Posted by llaliberti on
D. Floyd Kolb
  • Danby Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 12, 2011
2 Related Answers
imufo2
Leo Ponder
  • 3773 Answers
SOURCE: freezer over cold & refrigerator doesn't
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 26, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Freezer and Refrigerator are not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 08, 2011
2 year old Bosch B22CS is not keeping temp low enough.
Check the condenser on the bottom back side of the fridge if it is plugged off the freezer will not cool enough. If the condenser fan motor is dead then the freezer will never cool down enough. If that doesn't do it then you are looking at a waxed up cap tobe in which care you will need a professional to take care of the problem. Good luck
Sep 08, 2012 | Bosch B22CS30SNS (22 cu ft) Side by Side...
Freezer and Refrigerator are not cold enough. Freezer barely keeps things cold and fridge doesn't keep cold at all.
heatman101
Jul 07, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE TBXW25R Refrigerator does not keep cold enough temp in freezer and Freezer has a build up of frost begining
heatman101
Jun 02, 2011 | GE Refrigerators
The temperature in our refrigerator (Whirlpool Gold GD22DF) is not low enough this morning. Things don't feel cold. I've moved everything to a cooler and removed a small block of ice in the vent...
possibly the air damper motor has failed and needs tech help . you can possibly get by blocking the air damper open slightly but permanent fix needs done
Oct 08, 2017 | Refrigerators
I have a GE side by side refrigerator GSH22JST and frig is cold but freezer is not cold enough (soft ice cream)...heavy frost is building up on bottom half of evaporator. I can force defrost mode through...
Okay,
What is your Freezer temp rating?
Did you check the refrigerant PSI rating?
Is your condenser restricted?
Let try adjust refrigerator to less cold and adjust more cold for freezer. and see what your temp rating.
[email protected]
Jun 09, 2009 | Refrigerators
Freezer cold not frozen, fridge cool but not cold enough.
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
May 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Amana Fridge with bottom Freezer
either the switch or the temp sensor it broken. on the sears site you can get the part number
Apr 24, 2008 | Amana ABB1921DE Bottom Freezer...
Danby DFF8802 Top Freezer Refrigerator Logo
493 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
