SOURCE: Problem with the Nikkor AF-S DX 55-200 zoom lens.
I just had the same exact problem! However, in my case I was finishing up a photo shoot at work, went to switch lenses, and when I picked up my 55-200mm zoom lens, the tip of it fell off!! I was able to put it back into the end of the lens, but now I am having the same autofocus problem and sound effect. I think it is because it is off track inside the lens. But I have only had mine for 5 months! I'm preparing to send it to Nikon for warrenty repair.
SOURCE: nikkor af-s 18-200 VR not focusing
Please check your focus settings in the camera menu. Play around with the focus point from Single to 11 points. Also, try Auto mode as a quick way to test if the focus is working
SOURCE: My Nikkor AF-S DX VR 18-200 stopped focusing
the lens internally has a electrical circuit ribbon that contracts when you adjust the lens everytime. They are prone to get crease causing a short in the auto mode.b It can be checked and replaced bt most camera technicians
SOURCE: I have a D90 Nikon, I mounted my Nikkor 50mm 1.8d
Make sure you set the aperture ring on the lens to its smallest setting (largest f/number) and lock it. Without doing so, the lens will not communicate properly with the camera and thus you will not get the autofocusing.
