Question about Nikon COOLPIX P100 Digital Camera
Dropped Nikon Coolpix P100 camera -- grandchildren!!! Now there is a soft "clicking" sound when I turn it on and the outer upper and lower right corners are rounded and black. When I zoom in the black corners seem to go away, but are still barely there. Can it be fixed or should I just "give up" :-(
Posted by dowdclan2 on
Don Eagan
    Master:
  • 714 Answers
The Coolpix is a generally inexpensive camera. You have internal damage to the camera from it being dropped. It will cost you more to have it repaired. It is the way of the future. Most items are being made as "disposable" when they no longer work.
Posted on Nov 29, 2017
Lawrence Oravetz
  • Nikon Master
  • 10,548 Answers
The lens doesn't align with the sensor any longer. The body is bent, so I think a repair is impossible.
5 Related Answers
Glyn Kendall
  • 146 Answers
SOURCE: red hand blinks on screen upper right side. how do
The red hand icon flashing shows that the camera is using a slow shutter speed, and is a warning to be careful to hold the camera steady.
You could put the flash in auto mode and it will fire when the light is low.
Posted on Jul 16, 2009
  • 102366 Answers
SOURCE: lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Posted on Dec 31, 2009
Ty Price
  • 11967 Answers
SOURCE: Nikon Coolpix p80 blacked out, rounded corners
Have you attached some sort of lens shade to the front of the lens? The vibration might have something to do with the shake reduction system but I can't be sure. It certainly shouldn't vibrate heavily. You might get a better answer if you e-mail the tech guys at the support section of the Nikon website.
Posted on Feb 19, 2010
Ty Price
  • 11967 Answers
SOURCE: Everytime I zoom in or out I get a lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 05, 2010
lock123
Andrea Lock
  • 6831 Answers
SOURCE: my nikon coolpix says lens error when ever i try
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Where may I get the software/owner operator manual?
Hello Jeannie,
You may retrieve /download the user manual from this web Link:
User Manual Coolpix P100 Nikon Knowledgebase
The software and firmware may be downloaded from here:
Nikon Coolpix P100 Software
Good Luck!
Rich Lilja
Jun 12, 2015 | Nikon COOLPIX P100 Digital Camera
Nikon Coolpix p100 will not accept card
When a camera formats a card it wants control of that card. It something else changes the card the first camera will think the card is corrupted and in a way it has. Cards are not that expensive. Please use one card in one camera and back up you files on a computer.. I have found NO problem with deleting folders on my cameras using the computer. You typically can REMOVE photos on a COMPUTER you should ONLY let the camera ADD photos. use one Card for one camera.
Feb 16, 2018 | Nikon COOLPIX P100 Digital Camera
My Nikon Cool Pic P100 will not record video
If the Nikon uses a SD memory card then the memory card maybe too slow.
Try using a class 8 or 10 SD memory card.
Dec 29, 2012 | Nikon COOLPIX P100 Digital Camera
Camera will not charge, shows blinking orange but will not turn on... when it does, it's to a "battery exhausted" screen or the lcd display with a low battery symbol. Also doesn't show on...
It could possibly be the battery or the charger itself.Try purchasing the charger it self.Use the old battery to see if it will charge it. If it does not charge you may have to purchase a new battery.as well.
Sep 06, 2011 | Nikon COOLPIX P100 Digital Camera
How do i turn off the red eye reduction indicator light on my nikon coolpix p100?
Hello,please start using flash,push the flash icon in multiselector and choose in menu flash mode (highlighted); then OK.
Best regards
Mar 07, 2011 | Nikon COOLPIX P100 Digital Camera
Nikon coolpix p100 user manual to print
Here you go:
Click on the Gray/black box for the printable version. You have to create a login and then enter your camera's serial number to access the printable manual.
http://support.nikonusa.com/app/answers/detail/a_id/16765
Mar 02, 2011 | Nikon COOLPIX P100 Digital Camera
Instruction manual for nikon coolpix p100
You can download the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Oct 13, 2010 | Nikon COOLPIX P100 Digital Camera
Nikon COOLPIX P100 Digital Camera Logo
Top Nikon Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you a Nikon Camera Expert? Answer questions, earn points and help others
