Sony KDL-40EX401 42" HDTV-Ready LCD TV Logo
Posted on Aug 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When plugged in, Sony Bravia KDL-40EX401 red standby led blinks 6 times and repeats. After pressing the power button the screen displays "Sony" with a tone and repeats this 3 times before returning to standby and continuing to repeat blinking 6 times. I don't have the service manual but from internet research learned the blinking meant a problem with the inverter board. I replaced the board and after plugging the tv in, the light then began blinking 2 times repeatedly. When powered on, the screen displayed the logo with tone a few times the same as before but after returning to standby the red led was blinking 6 times again and no longer blinks 2 times even after being unplugged and plugged in again. I know the 2 blinks means a power supply problem and suspect that may be the real culprit, but I don't trust the blinking anymore. After further research I tested all the power supply voltages that were printed on the board. 24vdc pins to inverter read 25. The 12v pins for the other connector read correctly, too. How can I determine which board is really at fault? Could this be a problem with the LCD panel, even though it does light up and display correctly, although briefly?
  • 11 more comments
  • dreystoke Aug 12, 2011
    Hi, thanks for responding. Yeah, I should of known it wouldn't give me such a simple solution.
    I checked the voltage on BL_ERR and it reads 3.27v in standby. When the set is powered on, it goes to 0 whenever the screen turns on and then returns to 3.27 in between those three times and when it's in standby again.
    Hmm...I thought I did. I got it off Ebay, described as pulled from a working unit and guaranteed not DOA. Maybe something else I shouldn't of trusted.
    Is it possible something else is damaging the inverter boards, because I did get 2 blinks repeating the first time I plugged the set in after I replaced the inverter. After I powered the set on, I never got the 2 blinks again. Is there a way to test whether the inverter board is good? You also say it's possible the BL_ERR reading could mean a problem with the main board. Is there something I can do to check that?
    Okay, I'm willing to replace the main board too if that's where the problem is. I cut the BL_ERR lead going from the power supply to the main board (no problem to solder it back later with shrink tube), but I also cut the BL_ERR wire to the inverter by accident. Hope that doesn't mess up the test. The thing is, the line to the main board seems to be an input. Before I cut it, it read 3.27v at the main board terminal. After the cut it still reads that on the main board and 0 at the power supply. Is that the way it's suppose to be? Anyway, the screen does the same thing: lights up with logo and tone three times and then back to standby.
    Alright, we're getting closer. When plugged in now I get the audio of the channel but not the picture. Actually, the picture does seem to be there. It's difficult to tell but when I hold a flashlight up to the screen I can barely see the picture. So its just that the backlight isn't staying lit after it turns on for a few seconds to show the Sony logo.
    Oops, still learning how this site works. I didn't see the rest of your last message and sent a reply. If you didn't get it this is what I wrote:
    Also forgot to add that standby isn't blinking anymore. Want you to know I really appreciate your help with this. I realize my measly 15 bucks doesn't really cover the knowledge and experience you guys give generously.
    Oops, again. Thought your last message was the one before. Give me a sec to check BL_ON at the main board.
    It's very strange. Voltage reads 3.25 for BL_ON at both the main board and inverter board and yet the backlight doesn't stay on.
    The current inverter board is a replacement that's suppose to be good, so I swapped the original board back in and the voltages are the same and the tv does the same thing: turns on and I can hear audio but the picture becomes black after the Sony logo and tone. I wondered if it might be dimmed all the way and checked the dimmer voltage. It's 3.2v when the set is first turned on then drops to about 2.2 when the screen comes on with the logo and then drops to 1.6 when the screen goes black. Does that mean anything?
    Could I use the 3.3v standby voltage pin on the power board?
    Alright! Guess that was it because I've got the picture now too. Closest resistor I had handy was 2.2k and first used the 3.3v standby pin but I forgot to cut the lead to the dimmer and it didn't work. So I used 3 volts from a universal power supply with the 2.2k and of course still didn't work until I realized the lead from power supply needed to be cut. So the standby voltage probably would work. So would a solution be to run the set jury-rigged like this or do we know which board needs to be replaced?
    Great, thank you. I went from thinking the tv might be a lost cause to having a working set and knowing the right possibilities for a more complete repair. I'm very satisfied and will be accepting this solution. Thanks again.
    I'm very happy with this solution. The tv is working now and I don't even have to replace any boards if I don't want to. I highly recommend this site and the expert who helped me, welcomejee. He zeroed in on the solution from the start and answered all my questions. It was a pleasure working with him.
    I hope I'm still able to thank you for responding. I've accepted another solution but I appreciate your time and the information.
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Aug 12, 2011
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957548
Points
33084
Check BL_ERR pin on back light inverter board, what is volt reading that you get before and after tv shuts down? Let me know to proceed.
Thanks.
BTW, I really enjoyed your quote * I don't trust the blinking anymore *
  • 9 more comments
  • Anonymous Aug 12, 2011
    OK, BL_ERR should remain close to 0V because it is Balancer Error signal that shuts off tv. Balancer error shows bad back light inverter board and/or main board problem.
    Are you sure you got good/ working back light inverter board as replacement?
    You know there is no schematics for inverter or main board of LCD TVs and board swapping is the only option to rectify the problem.
    Reason of 2 times blinking would be due to misaligned connectors on power board or on inverter board while replacement. Only 24V goes to inverter board and its still available that means inverter board is working.
    If you can disconnect BL_ERR output temporarily going to main board that may help you to narrow down the problem, if main board gets 0V as BL_ERR then back light should remain On.
    Its OK, now ground BL_ERR pin on main board to check is it generating error signal itself?
    OK, that means BL_ON goes low/ off at inverter board and that command comes from main board, check is that happening?
    I'm going to bed now and wont be online for next 8-10 hours so do not reply this post OR site has 4 hours timer and we will lose contact and your question will go to open question area for other experts.
    Hey, I'm up and running again.
    I'm working at Fixya since last 3 plus years so I get all your messages/ posts/ comments, no problem at all, you know I know my ways.
    Regarding BL_ON command, its present all the time and back light still turns Off that shows inverter board is not good.
    There are just few connections in connector to do the job, Dimmer, BL_ON, 24V, GND and BL-ERR in case of problem.
    BL_ERR is cut off so main board is not getting any error signal, BL_ON is on all the time, 24V is available all the time, GND is connected, what else is left now? ... Inverter Board !
    Swap it in another similar model, if its possible to verify it.
    Yes, Dimmer is also command to control light intensity of inverter board, can you provide it 3.2 volts externally?
    I hope you will use 1K resistor to apply 3.2V at dimmer pin.
    Yes, and I would suggest to use 1K or similar resistor to avoid any current drain in dimmer circuit.
    Good to know that you got picture in tv.
    We just fooled the protection system in tv to turn On the back light to get picture in lcd panel. There are two boards that should be swapped in working tv to find out which one is bad.
    Usually I have this option in my repair shop or get it arrange to swap the board then I order replacement board.
    If its your personal tv then you may keep using it with same arrangements as its not harmful.
    oops, forgot to mention those two boards, back light inverter board and main board.
    Thank you so much, you did great job indeed.
    Have nice time.
    I'm from Pakistan and hopefully will be available for any help in electronics stuff.
Bud Martin
Level 3:
  • Master 11,361 Answers
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368897
Points
33650
These service may be close to your chassis:
http://elektrotanya.com/?q=showresult&megnev=sony&megnev2=KDL-40ex&kategoria=&kat2=all
Since the backlights inverter board is also used in the EX400/403/500/701:
http://www.shopjimmy.com/samsung-lj97-02541a-backlight-inverter.htm
Then you can download the manuals for the EX500 to see if it will close enough to troubleshoot the problem. I myself do not go by the blinking lights any more, it is only as good as the person that write the software/firmware to detect the faults that can be caused by more than one component failure.
Please post back what you find, I will have to download the manuals and see what it can be also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
2answers
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Standby light flashes 4 times
One option to try is to try to factory reset the tv, to do this turn the tv on hold the Down Arrow on the remote and while doing this press the power button then release the down arrow button.
Bit of info on your issue
* Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Trend to find everything
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
1helpful
My KDL sony tv turns on briefly(displays menu) then shuts down, and standby led flashes 6 times then pauses then continues, does not respond to the on/off button or the remote
6 times blinking standby light indicates problem with Audio Section in tv
Check AU 15V output of G2 (power supply) board then check AU board as it has sound processor and sound output ICs.
If you are not familiar with electronics stuff repair then call local tv repairman to repair it for you.
Thanks.
T.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
