Cell Phones Logo
Posted on Aug 12, 2011
MOBILE IS LOCKED..HOW DO I FIX IT - Cell Phones
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Aug 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
2728
Points
36
It's your Phone locked to Network or security code?,If it locked to Network means you can unlock it using the Network Unlock code,It locked to security means you can use the master reset code to reset from security lock,You can get the reset code or default code from service provider,Or If it alactel or Nokia means you can get the master reset code from here
Theunlockarena.com and reset it...you can specify the Brand and model?It locked to which Network ,Country it locked to Network Means specify above details and get the code from there and Unlock it.
1helpful
SIM not valid
If your Nokia shows the error message "Invalid Sim" or "Sim not valid" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your . To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
1)Go to Options>status
2)Find IMEI on the back of your mobile, behind the battery.
3)Type *#06# and press call button. It will display your IMEI number.
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Mobileunlocksolutions.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Samsung c3212
If your mobile shows the error message "Invalid Sim" or "Sim Rejected" or "Sim not supported" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Samsung C3212 . To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
Aug 26, 2013 • Cell Phones
Sim not valid
Hi if your Nokia 1209 is locked to network provider then if you insert other network sim then it will display message like invalid sim ..To fix this you have to unlock your mobile from that network ...You can easily unlock your mobile using network unlock code rendered by providers like Theunlockspot.com ...Here they provide unlock code for all mobile models locked to GSM network ....
Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so I am here to help you. If your Blackberry 8100 shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Blackberry 8100 . To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site WickedUnlock.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Insert correct sim card
Are you getting Sim card not accepting error message? If it is so then your Sony Ericsson W550i is locked to a particular network. To fix this you have to unlock it. Use unlock code to unlock your mobile from its network lock. To get the code you need to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
Invalid sim card
If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Blackberry 7290 . To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Unbblock.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
2answers
When i keep sim in my mobile it gives invalid sim
hi your mobile is locked to particular network so only it shows invalid sim when you inserted other network sim .to solve the problem you must unlock your mobile .there are many ways to unlock the mobile we can use software,cable,codes etc...among them codes are the best .to get the codes visit here classicunlocking here they ask the following details
mobile model
country from where you brought the mobile
imei number of the mobile
finally they will provide the codes to unlock the mobile.
1helpful
3answers
I have a motorola W160 and it`s sim locked. how can i get it unlocked?
My tens digit is 3 more than my hundreds is one less than my tens what number can i be
(there are 7 possible answer)
My phone is locked. could you please fix it? thanks
If your Mobile Locked to Network means You can get the Unlock code here
http://www.prounlocking.com/supported-phones/rs8wp7/ and Unlock the Mobile from the Network Lock.
Nov 18, 2010 • Cell Phones
I need a code to unlock my SGH-D415 t-mobile cellphone
HI HERE IS A SOLUTION CAREFULLY FOLLOW IT Warning: Do not enter any wrong unlock unlock codes on your Samsung SGH-D415 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-D415 mobile phone with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-D415 mobile phone is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-D415 mobile phone.
If it does not work, you can try these methods:
Method 1:
2 - ;;Phone;; will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-D415 mobile phone shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-D415 mobile phone.
3 - Compose : #0111*CODE#.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-D415 mobile phone.
Each Samsung SGH-D415 mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-D415 mobile phone at www.mobileunlocksolutions.com. HOPE YOU SUCCESSFULLY DO.... PLEASE RATE ME THANK YOU
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
