Question about Lite On LiteOn 16X Dual Layer DVD Rewritable Drive (DVDRSHOW1693S) Burner
My Liteon dvdrw cannot detect any cd - Lite On LiteOn 16X Dual Layer DVD Rewritable Drive (DVDRSHOW1693S) Burner
Posted by red_0000008 on
Brian Sullivan
  • Lite On Master
  • 27,725 Answers
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Posted on Aug 12, 2011
1 Related Answer
Anonymous
  • 788 Answers
SOURCE: hooking up a Liteon 24X DVDrw burner
The SATA drive is to be used with a motherboard that supports SATA 1 or 2.
If you have a board that supports SATA, you should also have a power supply that supports SATA.
The 7 pin connector is for data. the other connector is for power.
Hope this has helped you.
P.S. Their are conversion kits for the power supply if yours does not support SATA but your board is something else all together.
Get back to me with the make a model number of the PC and I will check if you want.
Posted on Sep 15, 2009
The liteon dvdrw will not burn a DVD
Perhaps you should reinstall the Sonic stuff, in case it was affected since the virus cleanup.  If the OS had some of its components quarantined from virus contamination, you are probably stuck reinstalling the OS...though of course you can search the web (and not least Microsoft.com if that's the sort of OS you use) for healing 'media detection' issues (w.r.t. your particular OS.)
Mar 18, 2010 | HP Pavilion a1610n PC Desktop
My SATA dvdrw drives are recognized, but don't find media.
try doing a firmwear update..make shure you are using dvd ram drivers...then when all else faild try loasding power dvd.. thats what i did and it werkd..
Feb 18, 2010 | Lite On LITEON 8X DVDRW +/- Burner
Hooking up a Liteon 24X DVDrw burner
Sep 15, 2009 | Lite On LITEON 8X DVDRW +/- Burner
It wont play any dvd disc
You should be install CyberLink PowerDVD Player and than try to play it.
Jul 23, 2009 | Lite On DVD+/-RW LITEON SOHW-1673S BGE %...
On my liteon 5005, i press''eject'' i hear clicks, but the tray will not open.help!!!!
Take a paper clip, bend it, and insert it into the small pin hole on the front of the player. It should be next to the eject button. This will open the tray up manually.
Mar 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
How do i fit a dvdrw into my acer aspire 1360
i had a go and striped my laptop down,inserted it screw it all back together and it worked, thats what i call { beginers luck }
May 22, 2008 | Lite On LITEON 8X DVDRW +/- Burner
LOST INSTALATION DISK
Hi, check here and you will find the drivers you need for your dvdrw. Thanks! /D
http://www.nodevice.com/driver/company/LiteOn.html
Apr 27, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Down load for dvd
well, you can start here with computer maker, to see if they have it..
Mar 04, 2008 | Lite On LITEON 8X DVDRW +/- Burner
Lite On LiteOn 16X Dual Layer DVD Rewritable Drive (DVDRSHOW1693S) Burner Logo
Top Lite On Computers & Internet Experts
Vernon Taylor
ray gallant
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
