Question about Amana ARB1917CSR Bottom Freezer Refrigerator
Do Amana refrigerators need to have a three prong grounded plug for them to work properly? I was told this was necessary and since my house was built in the early 60's when the code did not require a grounded outlet. I need to know because it will cost me several thousand dollars to wire my kitchen to the new code requirements. Thank you for your help.
Posted by gdebaca on
STEVE yes that one
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Amana Master
  • 35,495 Answers
No the ground is for your safety in case of short circuit. you can use an adaptor its up to you
Posted on Sep 25, 2017
5 Related Answers
Anonymous
SOURCE: Amana ARB2217C Fridge
its under the light bulb assembly in the frigidare compartment
Posted on Dec 29, 2007
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Does new defroster timer require adjustment?
 there are 3 components in the defrost system that can go bad. timer, defrost thermostat, and defrost heater. since youve already replaced timer that means youve eliminated it as a bad component. the most common defrost system failure is actually the defrost thermostat. moisture will infiltrat into the control and ause it to short out. the way to check it is:
  • unload freezer section
  • remove shelving
  • remove icemaker if applicable
  • remove rear access cover
  • once coil is exposed look for a round disc shaped peice that is attached to the top of the coil and has 2 wires going to it
  • hopefuly the control will still be frozen
  • using a multimeter set to ohms sheck for continuity on the 2 wires that go to control
  • if the control has continuity then you have a bad heater if no cont then bad defrost sensor
  • in alot of cases you will actually see that the control has seperated and come apart and you will not even need a meter.
I hope this helps you out. while you have unit pulled apart and after youv'e diagnosed the problem use a hair dryer to defrost ice build up on the coil. this will get the unit working temporarily until you get a replacement part.  thanks Peyton
Posted on Mar 19, 2009
Anonymous
  • 5 Answers
SOURCE: GFCI on refrigerator circuit cuts off.
Yes. Refrigerators should not be on gfci protected circuits. They should have a dedicated 120v circuit .If your kitchen is new enough to be wired with gfci breakers ,it should also have an outlet dedicated for the refrigerator.
Posted on Jan 09, 2010
Anonymous
  • 572 Answers
SOURCE: Is there a reset button on an Amana side by side refrigerator?
check the compressor relay.
Posted on Feb 08, 2010
Sheikhtijani
Shehu Pro
  • 1284 Answers
SOURCE: Proper refrigerant levels for Amana Side by Side refrigerator
Hi, normally the suction pressure on a refrigerant -22 system will be between 60 pounds gauge pressure (which keeps it above freezing point) and about 80 pounds. This depends on the temperature condition.Make sure that the superheat and subcooling are correct to see what is to be considered normal for the conditions you have present.
Take care
Posted on Jun 03, 2010
Is the grounding strap necessary for GE profile dryer
no-- but if you want to avoid electrocuting it would be a good idea to hook it up
Jan 24, 2016 | GE Dryers
Amana fridge is not getting cold
Check ur cold control thermostat, ur thermistors, ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Mar 28, 2015 | Amana Refrigerators
Is their any way to ground a three prong house plug-in from a two wire
replace the outlets to 3 prong IF there is 3 wires in wall if not you cant do anything except replace wire
Jan 16, 2012 | Dryers
Changing dryer plug
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 07, 2009 | Amana NDE2335AY Electric Dryer
I just bought a used amana dryer that is 1 year old. it has a 3 wire pigtail and i have a 4 wire plug in and need to change out the pigtail. need some direction on if possible to change it out or will i...
go to the local hardware store and buy the male plug for the female plug that you have in the wall just hook up the three plugh in place of the 4 wire plug. The 4 wire has a netural and a ground which is the same thing and two 110 hot wires that are 110 v each, hook up the copper colored wires to the copper colered wires and the one ground on silver. screw or white to silver wire. this is Ground you only need one ground and if the plug on the wall is three prong it is go to use a three wire plug the third wire is for a backup ground on new systems
Oct 04, 2009 | Amana NDE2330AY Electric Dryer
Four prong plug to three prong plug
Kalola,
You can if you want to, but it's not generally necessary. Here's a picture of a 3 prong configuration with a ground strap...
That green wire with the yellow stripe is a ground and it is most definitely connected to the cabinet somewhere. So it will serve as the ground strap (in the above picture).
Here's the thing... say you were going from a 3 prong to a 4 prong. That is, the dryer was originally "designed" for a 3 prong. This means you'd have to "retrofit" it a bit. Take a look at this pic... ( I made this for someone else, so please disregard my somewhat hostile remarks, OK?)
The ground strap has been removed and has been replaced by the ground to the frame. Yours probably does NOT have a ground strap, though... yours uses that Green/Yellow wire for frame ground.
All of that to say this. Don't lose sleep over it. Ya done good.
SG
May 01, 2009 | Maytag Neptune MDE6800A Electric Dryer
Need specifications
hi Laura
see the signs around the operating mode button.Drilling,drilling and hammering,just hammering.Try it and see what happens.
regards savumihai71
Sep 30, 2008 | Drills
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Amana Dryer
there should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Mar 18, 2008 | Amana DLE330RAW Electric Dryer
Amana ARB1917CSR Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
