Question about Texas Instruments TI-30XA Calculator
How can I find the square root of 39 on my ti-30xa? Also I would like to know how to find the cube of 9482... Help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Square root of 39: Press 3 9 [square-root] =
[square-root] is the key just to the left of the divide key.
Cube root of 9482: Press 9 4 8 2 2nd [cube-root] =
[cube-root] is the shifted function of the 0 key.
For other roots, you can use the [nth-root] function, the shifted function of the key above the divide key. For example, to calculate the fourth root of 16, press 1 6 2nd [nth-root] 4 =
Posted on Aug 11, 2011
Testimonial: "Thank you!you are awesome "
  • bjfods80fa Aug 13, 2011
    Hot summer day is about to,Open the wardrobe is not yet found love after
    another the right clothes? So, also waiting for? Immediate action bar!
    Welcome to {http://www.famalegoods.com } sure you will find what you need.
    Moreover, the company has a good reputation, product quality standards,
    at reasonable prices. Over the years, has been well received by overseas
    friends for their support. Therefore, please rest assured purchase.
    ++++http://www.famalegoods.com ++++++++++
    Best online store
    Best quality, Best reputation , Best services
    ---**** NHL Jersey Woman $ 40 ---**** NFL Jersey $ 35
    ---**** NBA Jersey $ 34 ---**** MLB Jersey $ 35
    ---**** Jordan Six Ring_m $36 ---**** Air Yeezy_m $ 45
    ---**** T-Shirt_m $ 25 ---**** Jacket_m $ 36
    ---**** Hoody_m $ 50 ---**** Manicure Set $ 20
    ---**** handbag $37 ---**** ugg boot $43 ---****
    ---**** sunglass $16 ---**** bult $17 ---****
How do you use the square root on the ti 30xa
Put in the number and press the square-root key (two keys up from the 9 key). For example, to calculate the square root of 4, press 4 square-root.
How to do square root on calculator ti 30xa
Use the square-root key, two keys above the 9 key. For example, to calculate the square root of 2, press 2 square-root =
Now that I know where the square root button is on my TI-30Xa, how do I calculate a "geometric mean" when the equation inclues a time period? For example the problem is setup like this: 6...
You don't want the square root. In this example, you want the sixth root.
Press 4 5 2nd [xth-root] 6 =
The xth-root is the shifted function of the y^x key, located just above the divide key.
How do i do radicals expressions on a TI 30XA
On your calculator, in the 4th column and third row down you should see the root x symbol. In order to do a radical, just press a number and then press the root x and you shall get the square root of your number. Now in order to do this for cubed root, fourth root, etc, you have to hit the number you want to put in the radical, the 2nd key, look for the y^x key in the last column second row, and then the number outside the radical. For example, if you wanted to do the cubed root of 8, you would hit 8, 2nd y^x, 3, and you should get 2.
8helpful
Can I use the ti-30xa to find cube root, 4th roots, and 5th roots?
Use the x-root function, which is the 2nd function of the y^x key located just above the divide key. For example, to find the cube root of 8, press 8 2nd x-root 3 =
3helpful
I cant figure out how to get the square root of a negative number
The square root of a negative number is an imaginary number, and the TI-30XA does not deal with imaginary numbers.
However, the square root of -x is equal to i times the square root of x. So, to calculate the square root of -4, for example, press 4 square_root = and read 2. Thus the square root of -4 is 2i.
6helpful
Finding a cube root on calculator
You can calculate cube roots by using the cube root function (the 2nd-shift of the 0 key). You can calculate arbitrary roots by using the x-root function (the 2nd-shift of the y^x key, just above the divide key).
3helpful
Ok im using the Ti 30xa how do i find the square root
1. Type in the number you wish to find the square root of.
2. Press the square root button. It is located to the immediate left of the divide button.
17helpful
3answers
How to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
15helpful
Cube roots
You use the y^x (y to the x) key along with the 2nd function key. That does the opposite operation.
So, let's pick something we know the answer to as an example. How about the cube root of 8? We know 8 = 2 X 2 X 2, so the cube root of 8 will be 2.
Here's how:
8 2nd y^x 3 =
The display will show 2.
The three is the root you want. You can put in any number, with 2 being the square root, 3 the cube root, etc.
Texas Instruments TI-30XA Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
