Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Posted on Aug 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony wega kv-34hs420 worked fine last night never had a problem with it before. Today i went to turn it on and i get no picture and the stand by light is blinking 6 times every cycle
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Oct 10, 2011
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336415
Points
2402
Your tv has problem in the horizontal circuit caps in the horizontal circuit should be checked also the jungle ic.and the regulator in the power supply.have a tech repair your tv if your are not a tech. good luck.
2helpful
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
My KV-34HS420 periodically displays an orange screen, then shuts down. The red light on the front flashes 7 times. The weird thing is that this problem occurs during the day, but generally not late at...
hi,
check ur tv for any dry soldering of component leads in the power supply and horizontal output side. also replace the electrolytic capacitor in the B+ supply rail.
u have to check the picture tube base board also for any dry soldering of components, if so the first mentioned complaint ( orange screen) will erase.
ok
Have Sony KV-34HS420 with no picture or sound. Timer/Stand By light flashes 7 times with pause in between. What is the likely problem and cost to repair?
Hold hair dryer to back right side on high heat for a couple of seconds while you hit the power button several times. It only took 2 times for my set to power on. Good Luck!
Sony WEGA KV-34HS420 television's colors all went to blue....trying to manually adjust this simply made them turn red and stay there. HELP!?!?!!
there are two possibilities for such type of a problem
the first one is the control ic which produces those three colours.
the second one is the crt tube if its about to finish such faults do come.
1helpful
Stand by time is flashing tv will not start
no the tv has no battery for memory.the memory is supplied by the 5 volt standby.the tv must be plugged in to maintain the 5 volts to keep its memory.
Sony KV-34HS420 Random Shut downs
i would say this is a internal problem how long have you had it?
15helpful
2answers
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
