Panasonic CT-36D32 36" TV Logo
Question about Panasonic CT-36D32 36" TV
The picture on my 31"
Posted by gekeye on
Anonymous
    New Friend:
It sounds like the tube has burnt out. Now that price of lcds have come down especially in that size class it will cost just as much to repair as it would be to purchase a new tv.
Posted on Aug 11, 2011
My sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
2helpful
Screen is black except for thin line in middle of screen
The problem is in the vertical section of the main board. Bad capacitors and maybe the vertical IC. If you are not inclined to be a tech you will have to take it to a shop.. I don't know what they may charge but I normally get $69- $89
Sanyo 31'' Standard Def CRT TV
This is a vertical problem that can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages present inside hte set even when unplugged. If you wish to attempt this repair, please update this and confirm your model number as DS31590 and I'll supply additional details and instructions.
Dan
2answers
Picture tube
no you have no vertical bad chip ic
1helpful
2answers
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
2answers
Sanyo DS31520 31 Picture problem
hi there, it is worth for fixing it, cheaper than replacing it. you have a vertical section problem. look for a quilified service personnel for it to fix. ty
1helpful
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
2helpful
Picture goes to one thin horizontal line in middle of screen
There is a bad solder connection in the vertical sweep circuit. if you know how toi solder, go and find the vertical output IC and resolder that first.. but if you have no solid state electronic repair experience, please find a trained tech to assist you in this repair, as if you wait it may end up costing you double of what it would now, so haveit done ASAP. Good Luck Please do not forget to rate this one.
Top Panasonic Televison & Video Experts
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
