Question about LG BH08LS20 Blu-ray Burner
I got the old 407291 software version on my machine and would like to upgrade my firmware, but LG says : Contact your dealer --- Please help
Posted by susi601960 on
Brian Sullivan
  • LG Master
  • 27,725 Answers
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
WARNING: Never update the firmware if the problem you're having is the drive isn't seen by windows, won't write with the included software, or other interface related problems. Unless the firmware specifically states it fixes the problem you are having, firmware updates normally don't fix these types of problems. Trying to update the firmware when there are interface problems can damage the drive's firmware. An error when updating the firmware is usually caused by a problem with the drive interface or there is more than one drive connected to that IDE channel.
IMPORTANT: do not interfere with the drive during the firmware update. If an error occurs during the upgrade process, or the upgrade process is cancelled during this process, damage to the drive can occur. If you experience any problems or have any questions, please contact our LG customer support line toll-free at 1-800-243-0000.
hope this helps
Posted on Aug 11, 2011
200E freezes up
A 200e that locks up usually need a memory and a firmware upgrade. The original 200's only have 32mb of internal memory. The upgraded mini print board that is used in the 730 has 64mb of memory. This 64mb board was used in the 200 as a upgrade and this stopped the lock up problem. Also over the years Bernina has improved the firmware and this also cures the lock up problem. The latest and probably last firmware version for the 200e is version 5, also called the cutwork version. The easiest thing for you to do would be to take your 200 to a dealer and have them install a 64mb mini print board and also upgrade your machines firmware to the latest version 5. Also if you have loaded embroidery designs in your machine, remove them as they use up the machines memory. When you get too many designs loaded even if you have a 64 MB board in your machine you can still have lockup problems.
May 28, 2014 | Bernina Artista 180
Can any one help me for cv 33 please
There are many versions of Casiovision software. The CV version depends upon your country. If you use the wrong version, you could damage the program. You have to match the IPL firmware in your machine to the software. For this reason, it is controlled by dealers. All you need to do is contact a local dealer and ask them for it. Most dealers will give it to you at no cost. They may charge you for training and this is reasonable because the machines that connect to CV33 are complicated POS terminals.
Most machines can be programmed and used without CV software so it is not essential to programming or operating your machine. You can program them via the keyboard on the terminal as long as you have the manual. If you need the programming manual, most Casio manuals are at C-tech:
http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
Jan 26, 2014 | Casio Parts Cash Register PC Desktop
Software for singer sew ware 1.0
Ask the dealer for the disk. If they don't give it to you, try the version 2.
As long as it isn't an upgrade from the old version, you shouldn't have a problem.
The read/write card should have come with the machine. Contact the dealer.
Any problems should be reported to the company.
Apr 10, 2013 | Singer Quantum XL-1000 Computerized Sewing...
I've upgraded the FW on my LG 47LE5500 and now the TV is not succeeding to start - looping reboot
Ur tv Firmware u upgraded it have corrupted files or the wrong version.Sorry ur main board tv Tuner signal board it have corrupted in it softwares or the wrong version in it CPU programming now.This problems,u cannot be undone or put the old version back.Only can repair by doing replacing a whole refurbish new tv Tuner signal board only now.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main board tv Tuner signal board for the replacement.
Aug 30, 2011 | LG 47LE5500 TV
Where can i find firmware updates for LG GSA-4163B dual layer burner - believe it to be A106
Hope this helps you
Aug 21, 2011 | LG (GSA4163B) DVD±RW Dual Layer...
Hi. I am looking for Vista drivers for the Canon DR-7080C. I see some on the Canon Europe website but it says I need to upgrade the firmware and I am not sure which version the scanner has already. Any...
I have many years of repairing Canon scanners and here is my suggestion to you.
You can also get them on the US site also, I will include the link for the drivers in this response. The problem your going to have is that to upgrade your firmware you need a piece of software to upgrade the firmware on your scanner. That piece of software is only released to canon dealers and its also used for diagnostic's of your scanner and to make adjustments to your scanner. I would contact your local Canon dealer, and ask what they would charge you if they came out to do this service for you, or what would they charge you if you brought the scanner to them to cut down on the cost of this very simple update. It only takes a couple of minutes to upgrade your firmware on your scanner. Below is the link to Canon's website for the files you need. I hope this helps you out.
http://www.usa.canon.com/cusa/support/office/imageformula_scanners/imageformula_dr_7080c/imageformula_dr_7080c_color_production_scanner#DriversAndSoftware
Apr 01, 2011 | Canon DR-7080C Flatbed Scanner
Picture freezes
Contact your LG dealer for a service engineer, the software version currently in the TV may need updating, there is an update available for picture freeze problems.
Jan 08, 2010 | LG 42LG30 42 in. LCD HDTV
Hello! I have a RC79T and I cannot record one of my cable channels. It is the national grograhic channel. everytime I try to record it get a pop up and says that this is copy right program, cannot be...
I have the same problem with FX. I e-mailed LG customer service and recieved this response,
We’ll be glad to assist you with this situation. A firmware upgrade will be required in order to correct the problem that you are experiencing.
Please reply this email with the following information:
Model number
Serial Number
Date of Purchase: 09/13/09
Firmware/Software version of the unit
Physicall address to send you the firmware upgrade
To get the Firmware/Software version of the unit try the following steps:
1.Select TV Aspect from the Setup Menu.
2.Highlight the 16:9 Option
3.Type in the code 1397139.
4.The System Information Screen will appear.
From this screen ask the customer to read
the current Firmware/Software version of the
unit.
Once we have all the product information we will be sending you a firmware upgrade, that will solve the issue that your unit has. I replied to the E-mail and now awaiting the arrivial of a disc with the firmware upgrade. Hope this gives you a starting please.
Aug 11, 2009 | LG RC897T DVD Recorder/VCR Combo
Firmware support for lg kp500
LG mobile uk, have now released the newest firmware for KP500 Cookie V10d, BUT with also the Flash Loader Utility Programme that has stopped many of us upgrading the mobile, I have waited 6 months!!! But as of yesterday I was able to finally install new firmware. Follow the instructions, installing software PHONE SOFTWARE UPDATE then when you install it will take you through each step and install flash programme and drivers, once these are install it will ask you to take out your battery and connect the mobile to usb and pc, this will load the flash loader with success. Then remove usb pop battery back in connect mobile with connectivity PC Suite and away you go, it took about 25 mins and i am with Vista. Hope this helps so many. Take care and enjoy your phone without restarts!!!! Lisa
Mar 15, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
New blu-ray dvd's won't play properly
Latest version is v071101a. you can find it here and burn to disc.
Or contact LG for a disc.
As a work around you might try to switch between PCM and bitstream and see if that helps.
http://www.blu-ray.com/firmware/firmware.php?id=17
Since the LG combo platform doesnt suppourt many HD features if you are thinking about buying new Blu-ray player (since the format war is over) I would go with the PS3 - best value for the price, is already set up for adavnaced features such as internet connectivity (with auto software updates), even if you dont use the game features.
Mar 22, 2008 | LG BH100 Blu-Ray Disc Player
LG BH08LS20 Blu-ray Burner Logo
141 people viewed this question
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
