Sounds like an impeller and seal kit you will need I think you impeller jammed up and the shaft stripped out the impeller or your motor shaft snapped
I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
SOURCE: frigidaire dishwasher...
It is very possible that something could be obstructing the main pump. But, first. Does your dishwasher fill with enough water? When full, the water level should fill to just below the heating element. You can check this by waiting for the fill cycle to stop and the normal wash cycle to begin. Open the door and check the water level. If your dishwasher isn't getting enough water, you could have a bad fill valve, or the inlet water line could be kinked. If this isn't the case, then suspect that you might have a clogged pump. Food particles such as popcorn kernels, orange or lemon seeds, small chicken bones and glass are notorious for getting into the pump screen area and obstructing the water flow (some of the other items I have found are labels off jars, bottle top seals, twist ties, rib bones, hair scrunchies, and yes - even band-aids!). Even though some dishwasher manufacturers advertise some amazing capabilities of their dishwashers, you still need to scrape your dishes of all food particles as much as possible. This does not mean you have to pre-wash prior to loading them. Anything that doesn't get dissolved by the wash cycle and detergent will end up sitting in the pump well. If the pump isn't able to pump enough water, your dishwasher will fill normally, but the spray arms will not turn, detergent does not dissolve and your dishes will not come clean. To get to the pump, you need to remove the lower spray arm and the coarse screen (located directly under the lower spray arm). The pump well should be located under the coarse screen. Look for anything that may restricting the water flow. I hope this helps and it's easy fix for you.
SOURCE: Frigidaire dishwasher does not clean
the start switch in the motor is probably bad,it could also be the motor relay.if you can get to the motor run the unit and while it hums try to turn the motor.it also could be something is stuck in the motor let me know.
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
SOURCE: LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs their any reset buttons for this type of washer?
SOURCE: frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
